Just got a new SA-12 2ohm DVC and threw it in a ported box w/ 1.75cft wired @ 4ohms only feeding it 300w and it's clipping, could it be the temporary enclosure it's in, or it being under powered, any other ideas?
How do you know it's clipping?
More detail on your complaint of "clipping"?
Enclosures can't cause clipping.
You can't harmfully underpower a speaker either.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
boxes dont make woofers clip. the user does.
underpowering doesn't cause clipping unless the user overdrives the amp.
The amp puts out 300w @ 4 ohms RMS, I've got the gain at 1.0v & there is no bass boost set on the amp/HU and it's clipping with the volume on my HU at 10 out of 40 (HU clips signal at 36)
I'm saying it's clipping because the sub is like, vibrating/distorting, you can hear it outside of the car w/ the trunk closed
Edited by Guest
How do you know you are clipping? Bass knob?
1996 GMC Sonoma
Four Fi BTL Neo 18's In 2:1 6th Order Bandpass
2 Ampere 5k's @ .5
TEAM FI
TEAM #LITHIUMCANTDEMO
On 10/20/2013 at 0:37 AM, KillaCam said:
Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
If you have the gain set at 1 volt, that's probably the opposite of what you want. Your gain says something like .5-5.0 volts right?
Your head unit puts out 2-5 volts most likely. So your amp needs to be set the same, not at the lower voltage. If your head unit puts out 4 volts
your amp needs to be set to 4 volts. Otherwise you'll clip.
2005 Subaru Outback Wagon Pioneer 9400BH Fi Q 15, SAZ1500dV3
The first build>>> http://www.stevemead...-outback-build/
140.9 @ 36hz Sealed on dash!
REBUILT!!! 2 Fi Q 15s, 2 SAZ1500dv3 146.9 @ 39hz dBDRA certified
Yes, I know subs are supposed to move. I don't have any equipment to test it with..but you don't always need equipment to tell that a signal is clipped...lol..
HU's preamp voltage is 4 volts, I never knew that TheBetterMethod.
Edited by Guest
  • Who's Online   0 Members, 0 Anonymous, 1770 Guests (See full list)
