hifonics brz 2100 or 2400?
Zach Martino
ive been looking at both these amps not sure which one I should go with , ill be running it on a sundown 18 zv3 , its gonna be for daily use , if anyone has any input on which will work better for that sub id appreciate! thanks!
depending on how much wrms the subwoofer is, i would get the larger amp. the more watts the better. make sure your electrical system is good though, 2400 watts is a good amount of power.
2013 Ford Focus Hatchback SE
Kicker CS61234
Kicker 40CS674
Kicker KST25
Sundown Audio SA-12 D2
Rockford Fosgate t1000-1bdcp
Rockford Fosgate t400-4
Audio Control LC7i
Kinetik HC2000
0/1 Gauge
Big 3 Upgrade
Beer, babes, and bass.
Neither.
Why get a nice sundown Z just to put a cheap amp on it? The BRZ line isn't all to efficient and will put some good strain on your electrical
Before I can suggest an amp... What do you have for electrical?
Honestly, I would get an AQ/SQ 2200 over those 2 amps, either Hifonics are very power hungry, and you would spend more money upgrading electrical to power them correctly.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I have stock alternator 0 gauge ran with an extra battery in the back and D2 gonna run it at 1 ohm , I have roughly 300 bucks to spend , if I have to spend a lil extra I will , I have a zrx 1500 at 1 ohm on 2 15s now and it works great
  • Who's Online   0 Members, 0 Anonymous, 1038 Guests (See full list)
