Aq3500.1 at .5 ohm power?
Mobileaudio25
Does anyone know what type of power it puts out at .5 ohm?? I'm looking into one because I'm really short on power right now. Also what type of electrical would I need to power it? I have 3 deka group 34 batteries and a 180 amp alt. ri know I'm gonna need to upgrade
why cant you just wire it to 1 ohm
I feel like lately its less important to give a full answer it the right answer. I feel line they just want an answer, even under advisement
that they shouldn't or it isn't recommended for many.
Im just gonna start giving the answer with no explanation
If your box is crazy efficient, you'll get close to the number I mentioned, if not, you won't. Voltage drop and imp rise, you'll.see that 3500 that you bought the amp for in the first place.
Idk about crazy efficient, but the box is definitely assembled perfectly and to perfect specs. It's gets pretty loud for a trunk car . I'd say between a 142-143.5 currently on 2400w rms.... But I know my speakers want around 3500 rms not to be hungry ... Or somewhere in the ballpark . I had ram designs do my box. 4.5 cuft at 36 hz
4.5 for 2 12" subs, that's some good airspace. Which subs are you running?
X2..
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 1004 Guests (See full list)
