nick6533 Posted March 28, 2013 Report Posted March 28, 2013 for some reason, fuses seem to confuse me. I have a few questions: 1. If an amplifier requires a 250 amp fuse, does that mean that its amperage draw is 250 amps? and thus you would need a 250 amp alternator? (obviously it would be more to accomodate the vehicle draw, but I'm speaking hypothetically). 2. If you run two runs of 1/0awg wire to an amplifier, would you fuse both runs with a fuse that is half of the amplifier's fuse rating? i.e. an amplifier that requires a 300 amp fuse, would each run of power wire be fused with a 150 amp fuse? 1990 300ZX Alpine MRX-M100 RE SE 12's Alpine CDE-121 Head Unit Alpine Type-S 6.5" Components Alpine KTP-445 Soon to come: Alpine CDE-136BT Big 3 with Knu Kolossus XS Power Batt up front HO alt Crescendo BC2000 SSA Zcon 15 Crescendo Concerto speaker amp Crescendo mids and super tweeters
MrSkippyJ Posted March 28, 2013 Report Posted March 28, 2013 1. No and yes. It's a give and take thing. It's a combination of battery and alt providing power. You can have enough alt power to fully supply the amp's needs, but it's usually easier and cheaper to use batteries to back up the alt. that's the short answer. 2. Fuse to the wires rating typically, not the amps. So in your example, use 2 300amp fuses. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
nick6533 Posted March 28, 2013 Author Report Posted March 28, 2013 Thanks for the help! So there is nothing wrong with having too large of a fuse? This doesn't put the amplifier at any risk? 1990 300ZX Alpine MRX-M100 RE SE 12's Alpine CDE-121 Head Unit Alpine Type-S 6.5" Components Alpine KTP-445 Soon to come: Alpine CDE-136BT Big 3 with Knu Kolossus XS Power Batt up front HO alt Crescendo BC2000 SSA Zcon 15 Crescendo Concerto speaker amp Crescendo mids and super tweeters
Wicks Posted March 28, 2013 Report Posted March 28, 2013 Power cable runs should be fused to the current rating of the wire. Amps should be fused to their power rating. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
nick6533 Posted March 28, 2013 Author Report Posted March 28, 2013 Well isn't the power cable's fuse also the amp's fuse? I don't see where you're coming from 1990 300ZX Alpine MRX-M100 RE SE 12's Alpine CDE-121 Head Unit Alpine Type-S 6.5" Components Alpine KTP-445 Soon to come: Alpine CDE-136BT Big 3 with Knu Kolossus XS Power Batt up front HO alt Crescendo BC2000 SSA Zcon 15 Crescendo Concerto speaker amp Crescendo mids and super tweeters
Tim Osburn Posted March 28, 2013 Report Posted March 28, 2013 the amps usually have a fuse on the amp. when you are putting the fuse at the beginning of the wire close to the battery that is protecting the wire for any shorts in the wire or over drawing the wire(pulling to much current). so thats why you get a fuse that is rated for what the wire is rated for. i you run wire that is rated for 125 amps thats the size fuse you should go with at the start of the wire run or smaller. if you go with a bigger fuse then the wire isnt protected.
Sonic Posted March 28, 2013 Report Posted March 28, 2013 Normally, the power wire current capacity is greater than the fuse rating of the amp. In the case of one amp, you can use the size of fuse recommended for the amp on the wire, this will protect the wire and the amp. and if you have 2 runs of power wire then run both runs to the one fuse rated for the amp. If you have more than one amp then use a fused distribution block, where each output is fused for the specific amp's capacity and the main power wire or wires into the distribution block is fused to the capacity of the wire. The above applies to amps that require external fusing.
nick6533 Posted March 28, 2013 Author Report Posted March 28, 2013 the amps usually have a fuse on the amp. when you are putting the fuse at the beginning of the wire close to the battery that is protecting the wire for any shorts in the wire or over drawing the wire(pulling to much current). so thats why you get a fuse that is rated for what the wire is rated for. i you run wire that is rated for 125 amps thats the size fuse you should go with at the start of the wire run or smaller. if you go with a bigger fuse then the wire isnt protected. The amps I've been considering are the AQ2200 and Crescendo BC2000, neither of which have fuses on the amp. So what do I do in this case? 1990 300ZX Alpine MRX-M100 RE SE 12's Alpine CDE-121 Head Unit Alpine Type-S 6.5" Components Alpine KTP-445 Soon to come: Alpine CDE-136BT Big 3 with Knu Kolossus XS Power Batt up front HO alt Crescendo BC2000 SSA Zcon 15 Crescendo Concerto speaker amp Crescendo mids and super tweeters
nick6533 Posted March 28, 2013 Author Report Posted March 28, 2013 Normally, the power wire current capacity is greater than the fuse rating of the amp. In the case of one amp, you can use the size of fuse recommended for the amp on the wire, this will protect the wire and the amp. and if you have 2 runs of power wire then run both runs to the one fuse rated for the amp. If you have more than one amp then use a fused distribution block, where each output is fused for the specific amp's capacity and the main power wire or wires into the distribution block if fused to the capacity of the wire. Thanks for the good advice. So if I'm running an amp that doesn't have a fuse in it, I should fuse to the amps fuse rating? Because in this case it protects the amp and the wire? (being that the fuse rating is at or lower than the wire's rating) 1990 300ZX Alpine MRX-M100 RE SE 12's Alpine CDE-121 Head Unit Alpine Type-S 6.5" Components Alpine KTP-445 Soon to come: Alpine CDE-136BT Big 3 with Knu Kolossus XS Power Batt up front HO alt Crescendo BC2000 SSA Zcon 15 Crescendo Concerto speaker amp Crescendo mids and super tweeters
larrys95civic Posted March 28, 2013 Report Posted March 28, 2013 are you running another battery in the back or going straight to your amps? Team Superior SPL Former Installer at Driven Sound & Security http://www.drivenss.com All kinds of forsale threads http://www.stevemeadedesigns.com/board/topic/164247-amps-subs-and-misc/#entry2383262 http://www.stevemeadedesigns.com/board/topic/164430-polk-audio-sda6000-sound-bar/#entry2386634 http://www.stevemeadedesigns.com/board/topic/164279-3-michael-kors-watches/#entry2383983 http://www.stevemeadedesigns.com/board/topic/164549-more-items-from-storage/ http://www.stevemeadedesigns.com/board/topic/166967-dd-9518s-amps-kenwood-custom-explorer-dash/ If someone is feeling generous I'd love an original sig LOL
