Question I always had with tires.. 31"+ tires
Why are the tires that fit 15" wheels less expensive then ones that fit larger size wheels?
I would think more rubber means more price?
This is in terms of 31" and up tires.
My guess is that 15 inch rims are most common among people with 31 inch tires. As you go up in rim size, the market gets smaller and smaller so the tire manufacturers have to charge more because they're not moving as many tires for the larger sized rims.
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
15's, 16's and 16.5's were pretty common rim sizes is why.
Hammerdown... 1%
that ^ ^ ^ ^
I used to work at a tire shop and ill tell you from ordering tires first hand from the manufacture, there is a big markup on 15" 31's and up. We can get ahold of 15" tires a lot easier than we could get ahold of 15&^. More supply makes it for an easier demand from the supplier
