SlamminBeats Posted April 3, 2013 Report Posted April 3, 2013 Ok so i have 2 DD M2bs strapped. All of a sudden on a cold start, amps were cool, my bass cuts off on a song ive bumped before. unstrap the amps and run each separately. the master amp doesnt work properly. It powers on fine but the output is gone. Even with the gain where it needs. you can feel the subs on, but they dont do a thing..basically like no bass. So is my output section broken on the board? I opened it up and see no burning, no lose parts. Everything looks normal. What could have happened here?
rocking.that.eclipse Posted April 3, 2013 Report Posted April 3, 2013 Can you get ahold of another amp to see if its actually your amp and not your head unit?
SlamminBeats Posted April 3, 2013 Author Report Posted April 3, 2013 Can you get ahold of another amp to see if its actually your amp and not your head unit? i have 2 identical amps strapped. 1 works 1 doesnt (when each is by its self)
Wicks Posted April 3, 2013 Report Posted April 3, 2013 Measure the resistance across the output terminals with subs disconnected and power off. Disconnect the RCAs and do the same thing at the signal inputs (resistance of center conductor to outside conductor). Make sure the outside conductor of your RCAs is connected to the negative power terminal on the amp. Focus on the center conductors of the RCAs and see if there are any solder cracks or something that would interrupt the signal into the amp. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
SlamminBeats Posted April 3, 2013 Author Report Posted April 3, 2013 Measure the resistance across the output terminals with subs disconnected and power off. Disconnect the RCAs and do the same thing at the signal inputs (resistance of center conductor to outside conductor). Make sure the outside conductor of your RCAs is connected to the negative power terminal on the amp. Focus on the center conductors of the RCAs and see if there are any solder cracks or something that would interrupt the signal into the amp. wish my dmm could measure ohms accurately
Wicks Posted April 3, 2013 Report Posted April 3, 2013 Measure the resistance across the output terminals with subs disconnected and power off. Disconnect the RCAs and do the same thing at the signal inputs (resistance of center conductor to outside conductor). Make sure the outside conductor of your RCAs is connected to the negative power terminal on the amp. Focus on the center conductors of the RCAs and see if there are any solder cracks or something that would interrupt the signal into the amp. wish my dmm could measure ohms accurately That could be a problem. How bad are we talkin'? If you can distinguish between 10's of ohms and kilo-ohms then that may be enough. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
SlamminBeats Posted April 3, 2013 Author Report Posted April 3, 2013 Measure the resistance across the output terminals with subs disconnected and power off. Disconnect the RCAs and do the same thing at the signal inputs (resistance of center conductor to outside conductor). Make sure the outside conductor of your RCAs is connected to the negative power terminal on the amp. Focus on the center conductors of the RCAs and see if there are any solder cracks or something that would interrupt the signal into the amp. wish my dmm could measure ohms accurately That could be a problem. How bad are we talkin'? If you can distinguish between 10's of ohms and kilo-ohms then that may be enough. like if you press it on the terminal, it will show a number for a sec then go away...its a cheap harbor freight one
Tim Webb Posted April 3, 2013 Report Posted April 3, 2013 sounds like preamp section has a bad opamp common issue when strapping
SlamminBeats Posted April 4, 2013 Author Report Posted April 4, 2013 sounds like preamp section has a bad opamp common issue when strapping should i send in for fixes? or is this like an easy solder fix?
Tim Webb Posted April 4, 2013 Report Posted April 4, 2013 its easy but if u know circuits. look up a guy named brandes.cm..im backed up atm...he can help u and his prices are good
