Wicks Posted April 4, 2013 Report Posted April 4, 2013 Nice thread Love that you started off with a PPI A600, One of my favorite amps ever. I have one if you need any more detailed pics to go along with the theme above. I have some contributions, if I may: Contrary to popular belief, the aluminum electrolytic capacitors used in basically all amplifier architectures are not for energy storage. They're for something called "decoupling" or filtering two different areas of circuitry. Electronic devices are built with the assumption that the supporting electrical supply is stable. There is no possibly way for those caps inside the amp to hold enough energy to actually power the amp if the supply current drops significantly which happens regularly when people try and use huge amps on stock electrical systems. The only amp (that I know of) that can support itself with internal caps is the Fosgate T15K which has a MASSIVE amount of capacitance inside it. A capacitor acts like a short circuit at high frequencies. When paralleled into a circuit, it helps to eliminate (short-out) higher frequency noise. Also, the voltage across a capacitor can not instantaneously change, therefore its great for voltage stability (noise smoothing). There are two main capacitor sections in an amp, before the power supply and after (Class D amps will have some in the output but that's another topic). The "Before" caps: These are physically the smaller of the two and are likely rated up to 25V. Its common to use a cap with double the voltage rating for reliability, when possible. They are directly connected to the power terminals on the amp and "decouple" the input of the power supply from any noise and whatnot in the vehicles 12V electrical system. The "After" caps: These are the larger of the caps and are typically placed in the middle of the circuit board. They are usually rated a certain percentage above the voltage of the power rails in the amp and will give you a rough idea of what voltage the amp's power supply is capable of. If you understand how transformers work then that is what's going on in the amp's power supply. The initial ~12V is pulsed into the input of the power supply transformer by the switching MOSFETs. This pulsed or switched voltage is now a form of AC which the transformer can use to step up the voltage. The transformer outputs this higher voltage "AC" signal which must be transformed back to DC for the output section of the amp to use it. The higher voltage AC is fed into a pair (or more) of rectifying diodes which remove the unwanted polarity of the AC wave. The rectified waves are then fed into the large capacitors which smooth the voltage into DC. The amount of capacitance and number of caps used depends on the amount of ripple voltage that needs to be smoothed and the output current of the amp. As you would expect, the larger the amp, the more capacitance is needed in the output of the power supply. Good idea on the illustrations, always helps to visualize what's going on. I have a few more additions which I'll throw out in a later post. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
HunterJohnson Posted April 4, 2013 Report Posted April 4, 2013 woohoo rate my amps next! Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
8ight Posted April 5, 2013 Author Report Posted April 5, 2013 I know the function of capacitors in the amplifiers, my explanation may have made it sound like they are being used as one would try to use a larger capacitor in a 12v charging system. I will have to revise the original post with a brief explanation about ripple suppression, stiffening. EDIT: I have used your explanation as a stand-in for my own as it is far more thorough, thank you for the contribution! I'm gonna hate
8ight Posted April 5, 2013 Author Report Posted April 5, 2013 Writing part II today on the subject of class D amplifiers, this should be more interesting to most of those posting here. I have selected my reference amplifier for the writeup as well: the excellent Sundown Audio SAZ-1500v2. Stay tuned! I'm gonna hate
purplesyrup Posted April 5, 2013 Report Posted April 5, 2013 great thread eight, can you do one on my eclipse 7232 amp? remember the one i took that chrome piece off off and we found a bunch of goodies in there? its a class d
meade916 Posted April 5, 2013 Report Posted April 5, 2013 had to remove some of the pictures. Feel free to re-upload pics that do not contain a URL to another site written all over it. thanks! All SMD products + MORE available at my store here! https://wccaraudio.com/ Subscribe to My Youtube Channel! Over 1,000,000 subscribers strong! Turn on your notifications! http://www.youtube.com/meade916 Follow My Instagram! Daily live feeds from the shop, exclusive content way before it hits my Youtube channel...and little squares with photo's in them http://www.instagram.com/meade916 The Official SMD Facebook fan Page https://www.facebook.com/SteveMeadeDesigns/ Follow my Tweet (Twitter) http://www.Twitter.com/meade916
8ight Posted April 5, 2013 Author Report Posted April 5, 2013 had to remove some of the pictures. Feel free to re-upload pics that do not contain a URL to another site written all over it. thanks! Sure! I will be re-writing this all with my own pictures eventually, I've got enough gut shots for the task luckily. I'm gonna hate
BrainzAmilkshake Posted May 9, 2013 Report Posted May 9, 2013 Any chance the class D write up is still going to be posted?
purplesyrup Posted May 12, 2013 Report Posted May 12, 2013 I have not seen eight on here for about a week it seems
