2 18" psi platform 2 box design
Can someone help me with a box design? I am about to order 2 18" platform 2 . with softer spiders so they are 1000rms. They are going on a crescendo 2000. I drive a 2003 Yukon and listen to mosty decaf and rap. I want it to get loud an brutal! My max dem are L36 H22 w 48 Thank you!
(2) PSI p2 18's
Crescendo 2000
Audio Technix 0 gauge/ SHCA 0 gauge
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
If you are picking a non standard sub, they should give you a box spec or t/s parameters to work with.
They said its the same exact thing as the platform 2 just 1000 watts rms. I kinda don't wanna order them unless I can get a box to work with
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
Bump. Anyone help me or tell me any good cheap websites to buy one?
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
this is what they emailed me back. They will change but slightly. the parameters on the site will definitely be very close. The Fs would be 1/2hz lower, with a slightly lower Qts, but not by much. It would basically be the same man. this is the
T/S Parameters for standard Platform 2 18":
Revc = 3.4 ohms
Fms = 24.3 Hz
Qes = 1.11
Qms = 8.54
Qts = 0.66
Sd = 1217cm^2
Vas = 254.1 L
BL = 15.5
Mms = 328.3 g
Sensitivity = 89.8 dB @1W/1m
Sensitivity = 91.4 dB @2.83Vrms/1m
Xmax = 56mm total
Usable excursion = 3.5" tot
anyone help out that would be great. dnt have the money to buy a design
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
  • 2 months later...
did you ever get one made man?
93' Exploder
Deck:Pioneer 6400-bt
Front Stage: Crescendo PWX 8"s and Skar Audio VX1-ST per door
Amps: Sundown Audio SAZ-3500 v1 @.375 ohm daily, CT Sounds 125.2
Subwoofer: Two PSI Platform 2 18"s,Fully Loaded D1.5's
Enclosure: B Pillar Fourth Order, 3:1 ratio tuned at 46 (Designed by Low Hertz Box Designs)
Wire: All Sky High Car Audio Cable!
Alternator: Singer 250 amp Hairpin
Batteries: XS Power D975
Team Audio Connections
ah yes I got it made and everything installed
(2) PSI p2 18's
Crescendo 2000
Pioneer AVH-P2400BT
yellow top optima
big 3 .
xs batt.
  • Who's Online   0 Members, 0 Anonymous, 492 Guests (See full list)
