running new amp in 300c
ThreehundredC
so I had this amp and it had to go back under warranty just got it back today
Hifonics zeus 2000.4 to run 2 selenium 8s ad 2 tweeters.for now but since i last had it i sold my double din and am back to stock i have one connection on the rear speaker for my sub amp ive had forever soi just tapped back in to that,
My question is What is the part i need for RCAs a cheap connection box wire tap type thing,,
i know a new radio would sound better but not using one
i have the harnesses that unplugs from the stock amp and like bypasses the amp then has bare speaker wire at the other end
well, if you are tapping into it before a stock amp then you likely already have a low level signal. It could be crossed over though.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
i have the sub tapped in the rear speaker but now adding highs amp ,, i think its this i need..
Pac-Audio C2A-CHY
but its like 80 bucks almost a new cd player
any other options out there same radio as any chrysler jeep dodge car
You might be better off just getting a new deck unless you have a really nice factory deck that you dont want to part with.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
i had the double din in there and everything ran good right to the radio but i sold it and put this back in hoping a 40 -50 fix could get my other amp running the shop hooked up the bass to it no problem bu that was like 5 years ago still works fine
  • Who's Online   0 Members, 0 Anonymous, 1038 Guests (See full list)
