Fiberglass And Fabrication Projects
Dozier
Yep the hose is for wires and such if you so choose to do anything real technical on it. I will have finished pics of the foam project and acrylic inserted, also the steering wheel and the box with acrylic inserts all tonight.
www.AlabamaDrift.com04 Silverado in the works
Ok..Now for the steering wheel build.
First thing, cut out the 1/2 inch mdf templates and flush trim them on the router.
Posted Image
This is the size of the acrylic insert.
Posted Image
Next cut out a piece of plexi glass to the shape of the inside of the steering wheel. Then duraglass up to the piece of wood that is cut out to be the template for your acrylic insert.
Posted Image
Posted Image
Posted Image
Posted Image
Next pre drill and counter sink three holes in the middle of the steering wheel and attach the acrylic center piece for flush trimming.
Posted Image
Posted Image
Posted Image
After flush trimming, it should look like this...smooth. Aside from the paper on the acrylic which is still on it until we are finished.
Posted Image
Posted Image
Posted Image
Now take the steering wheel apart. On to the fun part. Vinyl.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Now put together without the acrylic insert. Almost done. You can take off the paper backing on the acrylic now.
Posted Image
Posted Image
I have cut out a piece of acrylic to match the hole in the steering wheel. I will be using perma-trens to stick a picture to the back side.
Posted Image
All done.
Posted Image
Posted Image
Here are some good color combinations you can go with.
Posted Image
Posted Image
Posted Image
  • Who's Online   2 Members, 0 Anonymous, 1628 Guests (See full list)
