Need a quick answer to this seemingly easy question.
BASEheadDAN
Alright, long story short, i have 1 fosgate 2012 T2 dual 2ohm 12" woofer running on a T1000.1bdcp. Now, i have had many difficult times setting my gains by ear and finding that distortion sound, but anyway onto my question.
Would turning up all the dails to max on the amp, and hooking up a fosgate bass knob be the best way to go, or would i be better off keeping my gain about half, and lpf around 80 with zero punch bass.
Thanks.
Thing is, what i have heard is, if you crank all the dials on the fosgate power amps and hook up a fosgate knob, you will be able to control all of the gains/lpf/punch bass dials with the turn of that knob. I wanna know if this is true. Thanks...
No. Actually opposite
You connect gain remote and turn it all the way up. Then you set the gain. Then you can control from the remote.
And you still don't crank the other stuff all the way
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
Your gain remote gain only works from zero to what ever amp gain is set to
What you say us correct that if you turn gain to max you can control from zero to max but that's not the correct way to do it
If I set up remote gain
I set max at remote and set amp to -15
Then I adjust remote to -10 and -5 and place a mark at each
For radio I use anything up to full/-15 and cd -10max
As you'll find hard copies will be of different volume you of hu so clip at lower volume
But never set it above -15
And for the novice I normally check -10 and -5 and set max somewhere I between
Hmm... Interesting... setting gains on these amps is a difficult process.. i never know how far to turn up the damn things... im usually always around 80/xxx on lpf, and around half the gain on the amp... i never know to how far i can push my system without clipping... i saw a few os, and multimeters at the pawns, they might help.
thing is, i can pick up a 0-scope at a pawn... but i used a multimeter in the past, and after the tedious math, i came to the conclusion that at 3/11 gain, and 60/400 lpf i had a clean signal.. well, no thanks.. i dont wanna keep my system at 1/6th its potential..
  • Who's Online   0 Members, 0 Anonymous, 502 Guests (See full list)
