Michael Vest Posted April 9, 2013 Report Posted April 9, 2013 Please help me. I have a 1996 Mitsubishi Eclipse (base) and i want to upgrade my sound system. I only have a small battery and stock alternator (75 amps i think?). I am currently only running on 800 watt amp to 2 kicker cvr 12s. I plan to change EVERYTHING to soundstream. I have 2 soundstream monitors already and plan to buy the following: 1) VIR-3600 head unit 2) 2 pairs of the tarantula TC6.5 component speakers 3) 1 Picasso amplifier (P4.800) to power both pairs of component speakers 4) 1 15" SPLX subwoofer (soundstream SPLX-152HF) 5) 1 Tarantula (TX) amplifier (TX1.1300D) to power the sub That will use up almost all of my money beside money for resin and fiberglass. My concern is that this will be around 2000W PEAK power and im worried about my car. Can it handle all this power (plan to add 200w peak amp later) without major issues (i.e. shutting car off, starting a fire, etc)? I cant afford EXPENSIVE upgrades right now but if its REQUIRED i can do it later. Please tell whether or not my car can handle this. If not what can i do to make it work? Desperate for help before i spend all this money
Raptorman Posted April 9, 2013 Report Posted April 9, 2013 1k rms will be fine. Which is the "2k peak" you speak of. Just do the big 3 upgrade under your hood. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Skullz Posted April 9, 2013 Report Posted April 9, 2013 You can use a dodge SRT4 alternator in your car that is 130A instead of the 75a to 90a alts they come with. You will need to get a plug from either an dodge SRT 4 or dodge voyager turbo, the case may be just a tad long needing you to slightly modify the bracket but it is a low cost solution to a H/O alt. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2
Michael Vest Posted April 9, 2013 Author Report Posted April 9, 2013 ok im really unsavvy under the hood but there are plenty of tutorials i assume? Also Do i NEED 0 gauge or will my already existing 4 gauge work (i have plans to add another SPLX in future)
Michael Vest Posted April 9, 2013 Author Report Posted April 9, 2013 So for now im safe? but if i add more stuff ill need to upgrade alternator?
Raptorman Posted April 9, 2013 Report Posted April 9, 2013 Run 0 gauge for your Big 3. There are countless tutorials online. Google Big Three Upgrade and you will see. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
Michael Vest Posted April 9, 2013 Author Report Posted April 9, 2013 What is a good kit to buy? Is it safe to run a single 0 gauge wire (inline fused under hood) to the trunk to a distribution block that is unfused or do i need a fused one?
Michael Vest Posted April 9, 2013 Author Report Posted April 9, 2013 anyone have any experience with the SPLX subs?
SkarredSierra Posted April 9, 2013 Report Posted April 9, 2013 knukonceptz sells great kits on amazon. a real 4 gauge kit is like 30 dollars and the wire is actually 2 gauge. and you can buy it by the foot on the 0 gauge and its like 150 a foot i think so like 20 bucks for 10 feet wich should be enough to do your big 3. then you can get a kinetik power cell for like 100 bucks that will run a 1000 watt rms system with no problem. if you upgrade all that you should be able to run like 1500 to 2k rms with no problem.
SkarredSierra Posted April 9, 2013 Report Posted April 9, 2013 anyone have any experience with the SPLX subs? ive never had soundstream subs before but ik the rubicon amps are just beasts. you may look into using a rubicon series instead of the one you planned.
