pa-pa-platypus Posted April 12, 2013 Report Posted April 12, 2013 give the fuses a looking at.. it seemed to be a random case but i remember reading where a guy was melting the fuse and it was losing current through it (bad connection on the fuse)... voltage was fine but the fuse wasn't letting the amp get enough current causing it to diminish output after a song or 2.. its worth a look This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
Pauly1987 Posted April 12, 2013 Author Report Posted April 12, 2013 What would be my best option in that department? Just drill some wholes and run strait from sub to amp forget about terminal cups?
kl0wn Posted April 12, 2013 Report Posted April 12, 2013 What would be my best option in that department? Just drill some wholes and run strait from sub to amp forget about terminal cups? Bolts IMO. Get 2 bolts, 2 nuts, and 4 washers. Drill a hole the size of the bolt into the box, then slide it all together. Bolt----Ring Terminal----Washer----Box----Washer----Ring Terminal----Nut That's what I have always done at least. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
deathcards Posted April 12, 2013 Report Posted April 12, 2013 What would be my best option in that department? Just drill some wholes and run strait from sub to amp forget about terminal cups? that is what i would suggest don't forget to seal around the wire otherwise what kl0wn said skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
