HunterJohnson Posted April 13, 2013 Report Posted April 13, 2013 So I've been trying to get this figured out and I simply cant. I have a Pioneer 80 PRS and amps are Alpine MRV f407, F1507, T575 (Early 90's Expert series amps) I have tried turning them on, sending a signal through, trying to check with it off, and sometimes I get a conntinuity check and other times its blank. Can you guys please help me and also if you know if they are SE or Differential. Thank you! Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
ImaNoob Posted April 13, 2013 Report Posted April 13, 2013 I wrote a email to pioneer about my 7800mp, the responded with ( the output is a unbalanced signal ) .. I would do the same if your unsure Quote 2006 Dodge Ram 1500 Xs3400 1500BDCP FI BL 12 3sq @ 32hz Rockford t675 T400.2 Stinger Deadner Build Log Here
HunterJohnson Posted April 13, 2013 Author Report Posted April 13, 2013 (edited) Ok I have a theory.... LMK if this makes sense. When I hook up the amp on my test bench both MRV1507 and MRVf407 (the other one is in my car) The protection light flashs red which means: RCA GROUND FLOAT This makes sense because I don't have a common ground on my test bench, its just a 120V to 13.8 10AMP converter and the signal is comingfrom AUX-RCA Y splitter (twisted RCA). Basically this means the amps are SINGLE ENDED because it is looking for a common round between the RCA and the Battery (in my case converter) Edited April 13, 2013 by HunterJohnson Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
Wicks Posted April 13, 2013 Report Posted April 13, 2013 Use a DMM and measure the resistance from the RCA outside conductors to the device's chassis or ground terminal. If you see basically a direct short, it's single ended (unbalanced). Quote This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
HunterJohnson Posted April 13, 2013 Author Report Posted April 13, 2013 Use a DMM and measure the resistance from the RCA outside conductors to the device's chassis or ground terminal. If you see basically a direct short, it's single ended (unbalanced). so where would I ground it on my amplifier? Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
Wicks Posted April 13, 2013 Report Posted April 13, 2013 Everything unpowered and disconnected. Resistance between the RCA outside conductor and the amps ground terminal. General procedure: <1ohm = single ended ~1000-ish ohms = balanced No connection = your HU probly blew its pico fuse Quote This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
HunterJohnson Posted April 13, 2013 Author Report Posted April 13, 2013 Everything unpowered and disconnected. Resistance between the RCA outside conductor and the amps ground terminal. General procedure: <1ohm = single ended ~1000-ish ohms = balanced No connection = your HU probly blew its pico fuse So I guess my HU is SE and amps are DIFF so ill be going with twisted. Thank you! Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
HunterJohnson Posted April 13, 2013 Author Report Posted April 13, 2013 I got 20kohm on amps and .5 ohm on Hu Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
LordArcane Posted April 13, 2013 Report Posted April 13, 2013 sounds like with those reading, giving you don't have an unforeseen ground issues. coax head unit, twisted amps Quote
HunterJohnson Posted April 13, 2013 Author Report Posted April 13, 2013 sounds like with those reading, giving you don't have an unforeseen ground issues. coax head unit, twisted amps Yup this is with them standing alone. No power or connections. Twisted RCA's for me Quote Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
