How To: Find out if your head unit & amp uses coax or twisted RCA's
As stated this will help you or should help you find out what type of RCA inputs and outputs your head unit and amp uses.
sorry for the poor video, as i don't have a very good camera.
Part 1: Head Units
http://www.youtube.com/watch?v=q59EFRLZd_c
Part 2: Amps
http://www.youtube.com/watch?v=rhXCwD9hNDo
Hope everyone enjoys this little how to video.
also some other info you might need to know
SE=Coax, Diff=Twisted
Link to D'Amore Engineering's video "Truth about RCA signal cables"
yes its should, you will also be able to do this with everything out of car. you would just be assuming your car have great ground throughout.
given if you have good ground at your amp/ head unit you can use the grounds from them ( i.e. instead of me using the chassis ground i could have grounded my - lead to the neg power input on the amp and proceed with touch the outer rings.
Thanks for the video's. You mentioned another video in video 2 here. Where is that at, if you could link it please. I'd like to see it as well. Thanks!
was just the first video, when i had did the head unit, was just using it as example seeing as i got single input coming from deck and diff input going into amps
everything you should need info wise, should be in the first post.
What i think is so funny no matter what the amps required the ground signal on the shielded end it does not matter if its coax or twisted if you want real coax instead of half coax you can always use some Home R6 cable that u use on your tv and put this connector on it if you want real coax
http://www.amatteroffax.com/itempagey_invid_847201_d_cables-to-go-video-adpt-bnc-female-to-rca-male.html
Unitil then
Yes i work on amps thats why i HAHAH
buy yourself a 100 dollar wire and a 10 dollar wire cut them open to find out you have the same wires in side nothing different but the shielding for noise signal
  • Who's Online   0 Members, 0 Anonymous, 973 Guests (See full list)
