How to wire an Amplifier
Enzo
I thought the big three was Battery, Alternator and Cables? What 3 cables are we talking about then?
Read the link I posted. It's an upgrade for your charging cables
Oh wow I didn't know it was just those cables . I see in that photo the battery is a top post, mine are side posts, how can I attach the wires to it like that ?
They sell extended batery post bolts for side post batterys at any auto parts store ( im partial to advance auto because im a comercial account manager there) you just pull the stock bolt out of the rubber boot on the end of your cable, reatach it with the new one, then atatch the uograded cable with the nut on the outer portion of the new bolt. The new bolts are usually made of brass with threads on bolth ends and a nut one end. You will need two of those, aprox. 6' of good cable 1 or 2 gauge at least and 6 ring terminals that will fit your cable. You should also look into running 1 or 2 gauge cable for power and ground distribution blocks in the back where you can run short pieces of 4 gauge to your amps. Those steps will get you alot closer but you will probably still need a second battery in the back. Also allways fuse any power runs that are 18 inches or more.
Edit for www.advanceautoparts.com
I just wish i had a funny sig.
http://www.oreillyauto.com/site/c/detail/SS01/01391/N0365.oap?ck=Search_N0365_-1_2519&pt=N0365&ppt=C0005
Pretty much what he said above, with the exception of I'd run 0 gauge. And if you don't know how to solder, find someone around you who does. Mashing terminals on with a vice or hammer or something just doesn't cut it. I don't care how hard you think you can squeeze
Oh im sorry if you wont listen to larry then iv just waisted my breath. Or finger stamina.loll good luck. Btw from what iv seen larry knows his stuff. I would listen. Hint hint.
I have been listening to what Larry has been saying and its helping me alot. Im still young in the knowledge of car audio haha! Anyways i am considering doing the big 3, just have to find out the proper way to do it. I have been going over those forums a bunch of times but its still pretty confusing. Also i took my sub out of the box today to just make sure i did all the connections to 2 ohm which i have but i noticed the speaker wire going to the terminals on the box was 12 gauge and i believe i used 16 gauge to attach them to the amp. Is this why the sub i super quiet aswell? Like the sub is flexing but its not even close to being as loud as the rockford P2 i had on 400 watts
  • Who's Online   0 Members, 0 Anonymous, 751 Guests (See full list)
