Everytime I try to hook up a USB device to my garage computer, it freezes up solid. It does this with a little flash drive, external CD drive, anything... When I try to connect the device, then turn the computer on, it freezes on the XP screen.
I'm OK at computers, but I have no idea on this one..
Compaq Presario
3000 AMD
1 Gig RAM
Genuine copy of XP
Thanks...
Check out StoneSounds to see my recent builds.Or look at the Flying White Facebook Page!
I had a somewhat simillar problem, but it would shut down even befor xp loaded, i found out my front case usb ports wires came loose and were grounded on the case causing my PSU to go into protect. But in your case it sounds like a driver problem man. I know SP2 has all the usb drivers so maybe redownload that from microsoft. Try to get all the orginal Compaq drivers reinstalled with all updates as well....thats all i got for now
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
you can uninstall them through the device manager they should reinstall on thier own when you restart windows
is it a usb card installed into a pci slot in your computer or is it on your actual mainboard or maybe front panel? try out all the ports and see if thats the issue. go to your device manager and check out all the usb root hubs and restart your computer, they should reinstall automatically. ehh try giving system restore a shot and see if that will fix it. It might be spyware/virus related as well. I wouldnt try doing a bios update unless you have a good hunch thats what is wrong.... i doubt that will fix it. maybe a bios flash but thats as far as i would go with the bios.
Too Much Stuff to list .
Well, I found the root hubs, and uninstalled them, then the computer freaked out for a while.. wouldn't display anything, froze up, shut itself off a couple times, then finally booted up all of the way... Now everything seems to be working really well.. All three locations of USB's are working great... for now, but I'll take it.
Thanks Fellas, you guys are the s***t.
Late
