Xplay75 Posted April 19, 2013 Report Share Posted April 19, 2013 Running a rf 1500 bdcp,sub hums when disconnect the rcas just started happening when changed cars,subs wired to 1 ohm and amp is wired correctly Link to comment Share on other sites More sharing options...
pk222 Posted April 19, 2013 Report Share Posted April 19, 2013 Is this happening when I disconnect the RCA's from the hu or from the amp? If its when you disconnect from the hu it could be your RCA's Link to comment Share on other sites More sharing options...
Xplay75 Posted April 19, 2013 Author Report Share Posted April 19, 2013 It does it from the amp no rcas connection Link to comment Share on other sites More sharing options...
bkolfo4 Posted April 20, 2013 Report Share Posted April 20, 2013 Ground or amp problem. Easy fix - don't turn the amp on with the RCAs disconnected. . . Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz. Link to comment Share on other sites More sharing options...
Xplay75 Posted April 20, 2013 Author Report Share Posted April 20, 2013 Ground or amp problem. Easy fix - don't turn the amp on with the RCAs disconnected. . . ok ill check the ground out thanks for your help Link to comment Share on other sites More sharing options...
Xplay75 Posted April 20, 2013 Author Report Share Posted April 20, 2013 Do u think it could be the hu its a different one and could it have to do with the remote turn on,that's the only thing that's different from the old set up ill also check the ground to Link to comment Share on other sites More sharing options...
