jordan23 Posted April 20, 2013 Report Posted April 20, 2013 I just purchased this amp used locally. Now i'm still in school with no access to my car, so i have a 500 watt computer power i modded to use for bench testing. I hooked up the amp to the power supply and jumped the 12v to the remote and hooked up a cheap 300 watt rms 4 ohm sub just to check to make sure everything works. I powered it on, but i noticed as soon as i turned it on, the sub was moving a lot with no input. the amp is sending low frequency signal to the sub. Any help with this would be very appreciated! thanks, Jordan
deathcards Posted April 20, 2013 Report Posted April 20, 2013 could be the power supply have you tried using a small 12v car battery in line the power supply might not have a very good ground skar sk2500.1 0 gauge power and ground kunukonceptz alpine HUvxi65 components on BA gt-275new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821 2 x-15 sundowns singer alt, odyssey bat, and maxwell ultra caps
jordan23 Posted April 20, 2013 Author Report Posted April 20, 2013 could be very possible, i believe my symptom is called motorboating? and im using a 4ft length of 14 gauge ofc directly soldered onto the power supply. I read earlier that too much resistance in the wire creates this. and this is with the gain at 8v bass boost at 0 subsonic at 0 and hp at around 100 with no input at all.
jordan23 Posted April 20, 2013 Author Report Posted April 20, 2013 i just hooked it up to a car and it still does the same thing. I used 2 short lengths of 8 gauge to power it.
bighossf150 Posted April 20, 2013 Report Posted April 20, 2013 is the sub free air or in a box? Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
jordan23 Posted April 21, 2013 Author Report Posted April 21, 2013 free air, it moves quite bit with everything set to the lowest
