bolt size
depends on the size of hole in said lug lol
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
well what the common size for the 4 gauge?
I know the 1/0 gauge is the reg size one and not the smaller hole. will the 3/8 fit through the 3/8 hole without any problems?
Shakin not Stirred....my buildhttp://www.stevemead...ngle-cab-build/412 CVX
And put a sealed enclosure in your trunk cut a hole in your deck and call it ported :lol2:
Even if they are I'm sure you could drill and make the hole a little bigger
13 Kia Forte Build!
07 Hyundai Accent Build
***Super Seller***
N8ball2013
you can buy 3/8 and use a flat washer if it's too big. I would rather do that than try to drill through a 1/16" thick piece of copper.
I've had to do it before in a pinch, a unibit goes through relatively easy
TDH FTW !!!
  • Who's Online   1 Member, 0 Anonymous, 1993 Guests (See full list)
