Here are some pics of the smoker I built...we'll call it a dual chamber gravity feed reverse flow cooker. Only one in the world. The concepts are nothing new, but they havent been incorporated together before. Build time of about 6 weeks, 4 weeks of sitting there looking at a bunch of metal and thinking, 2 weeks of fab, not in that order lol.
Here is the firebox. 1/2" steel plate. It measures 10"x10"x12". The grate is 1" solid roundstock. The grate sits underneath the firebox.
"who cooks underneath a fire?" Lol, it will make more since here in a bit.
The firebox sits on top of the ash cleanout. The grate slides in the ash cleanout and hangs from the top of it directly under the firebox like this...2011-04-23214310.jpg
Very Nice !!!
Got a fairly nice size custom built grill myself (bought it, not built it) ...
At the back of the firebox is the fire/exhaust exit. Burning charcoal sits on the grate, heat and smoke exit through the jail cell looking hole.2011-04-26021022.jpg
On top of the firebox is the charcoal chute. This gets filled up with charcoal. From the grate shown earlier all the way up. Its tapered both directions to avoid blockage. As the charcoal at the grate is burning, it gets smaller. As the pieces fall through the grate, gravity feeds down more charcoal. Hence the "gravity feed" part. If it wasnt tapered, the coal could jam as it slides down the chute.
It's also important that the chute, and lid or door to the chute be air tight. Air gets to the burning coal/wood through the ashbox, and basically feeds the bottom of the fire. If the chute leaked air, the whole chute would want to go off.2011-04-30030518.jpg
The top panel of the chute hangs over both sides so it can attach to the cooking chamber walls. A cooking chamber on each side, like this..2011-04-30030543.jpg2011-05-01012031.jpg
I have no idea what you're doing but it looks good. In for the end result.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
lol KillaCam, thats what everyone said when I was making it. Dont know how many times I was told it wouldn't work, even by "engineers". Thanks!
