Running A 16 Volt Electrical System
I've recently discovered I'm able to get 16 Volt batteries here in Australia affordably In my new car I'll be getting a Mechman Alternator, how difficult is it to have the set voltage high enough to charge 16 Volt batteries? Is it something I have to pay extra for or can Mechman simply set it that way?
To provide electrical to my stock electronics all I need is an XS Power 993 step down module right?
What are the advantages/Disadvantages of running a 16 Volt system. The main reason I want to do it is to get more power from my Crescendo BC5500.
(Old Car) 1995 Volkswagon Golf MK3 2.0L:
Fi SP4 18 On A DC Audio 3.5K In A PWK Box
Hertz DSK 6" Speakers, Clarion HU
3x Fullriver 120aH AGM's, 225A Alt
2012 Subaru BRZ:
Audison Prima APK 163
Bit One, Rockford Amps, Audison Sub
If possible, get a second alt for the 16v batteries and run it isolated from the stock. Step Downs add a complication and a heck of a lot of heat. You will likely need more than 1 step down.
You are probably better off just getting a bigger amp than trying to go with 16v batts.
edited for bad use of then vs than.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Like tarball said can you run dual alts?
If I was you I'd just run the stock alt at 12v and the mechman at 16v to a bank in the bank.
Wouldn't have to use step downs then.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
  • Who's Online   0 Members, 0 Anonymous, 931 Guests (See full list)
