NYC54 Posted April 24, 2013 Report Posted April 24, 2013 I just got the bc5500 yesterday finally , the manual says 1 ground to the batt , where is everyone grounding the the second ground to?
Ben Fultz Posted April 24, 2013 Report Posted April 24, 2013 A good clean solid frame ground would work.
NYC54 Posted April 24, 2013 Author Report Posted April 24, 2013 So it has to be connected directly to the car frame ? It can't be sheet metal inside the truck ?
Crandis16 Posted April 24, 2013 Report Posted April 24, 2013 frame ground > sheet metal ground sheet metal just doesn't cut it, it's not enough metal My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
Ben Fultz Posted April 24, 2013 Report Posted April 24, 2013 Sheet metal isn't really a good ground since most panels are just tack welded. If enough welds break / come lose you lose your ground.
tacomaguy1 Posted April 24, 2013 Report Posted April 24, 2013 Are you talking about the dual grounds on the amp? Ground them to the same place Team Flex Issues
NYC54 Posted April 24, 2013 Author Report Posted April 24, 2013 Ok got it thanks guys I just wanted to make sure before I start making holes, this is my first amp with dual grounds and also my first real big amp
Emmet Posted April 24, 2013 Report Posted April 24, 2013 Sheet metal isn't really a good ground since most panels are just tack welded. If enough welds break / come lose you lose your ground. It's not because of the welds. It's because sheet metal in general is shit at carrying current. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
NYC54 Posted April 24, 2013 Author Report Posted April 24, 2013 Are you talking about the dual grounds on the amp? Ground them to the same place Yea the amp has dual ground inputs , so I was wondering where was a good place to ground the second ground , was just making sure
razon35 Posted April 24, 2013 Report Posted April 24, 2013 if you have a battery in the rear by the amp, ground both the amp grounds to the battery, then run 2 grounds from the battery to the FRAME, sand that shit good, use a bolt and nut, tighen that bitch solid!
