Voltage issue.... help?
do the eld bypass so you can constantly charge at 14.4
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
all under window line
Team DC Audio
Obama has a law he's trying to pass right now, trying to ban Leo for being a threat to children everywhere.
EDIT: Not in a JP kind of way.
I thought I was going to die from all the jizz filling my ears.
I did the ELD bypass and seems to work similar to when I have my headlights on without the bypass. I did took it out though. Could be that my distributor is at the end of it, but after few months with ELD my distributor went out on me suddenly at a stop sign. Needless to say it cost me over $200 for a new distributor so I took out the ELD. I also notice my car was running little rough too when I have the ELD so idk if I'm tapping the correct wires.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
BTW, had my AC running yesterday on the way home from work & headlights on with no music, my voltage was at 12.4v at red light.... smh.
theres a guide on here that shows which wires to use for the bypass
I'll be installing my bypass after work today, I used the guide to get everything ready
http://www.stevemeadedesigns.com/board/topic/139844-how-to-eld-bypass-for-honda-civicaccordfit/
2002 Honda CR-V
Alpine 9887
My Build
Rebuilding...
Second Skin Damp
4 DC XL 15's
2 DC 5ks
Singer 320 amp
6 cap banks
Sky High wire
2 VM-1's
OM-1
Team DC Audio
That's the guide I used. Adam confirmed the wires I tapped into as well. :shrug:
Check fuses and connections. What is your voltage if you read it directly from the alt casing and positive post?
All fuses are fine.... all connections are secured. I can double check later. I haven't check the voltage from the alt directly. I might do that later too.... I was thinking using one battery to start the engine and unplug the battery to let the car run off just the alternator. Car should die if alternator puts out voltage/current?
Don't do that. Short answer is the battery helps to smooth out the peaks and valleys in the power put out by the alt ;)
lol ok... i was just thinking about ways to troubleshoot the issue before taking it in.
  • Who's Online   1 Member, 0 Anonymous, 1146 Guests (See full list)
