Voltage issue.... help?
My car has this exact same problem. Its not the alt in my case though, its just how the cars computer works. Maybe you'll have a different result if it just randomly started acting like that
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
If its easily accessible maybe try to disconnect the ELD/bypass all together for a day or two. Then you can at least tell if its something in your bypass or actually your alt. It sounds like you did your research and verified everything but hey I'm sure it's easier than ripping the alt out lol.
06 Jeep Grand Cherokee
2 DC Level4 12"
Soundstream TA1.3000d
4 RF Punch 6.5" Components
2 RF Punch 3.5" 2-ways
RF Prime 400.4D
XS Power XP950 +&-run of XScorpion 1/0 OFC My Civic Build
My car does the exact same thing, now I don't drop to 12.6 or 12.4, but at idle i go to around 12.8-12.9 and I can't bump at all because the alt doesnt kick in. THen again, I am in a honda that has a ELD and may be restircting my alt from when it can output. Also I am on stock electrical with the big 3
  • Soon To Be
  • '04 Ford Escape
  • US Alternator 280A Hairpin
  • D4800 Under the Hood
  • (6) XP3000's in Rear
  • Pioneer DEH-80PRS
  • DD AW6.5 (2) per door
  • *Tweeter Unkown*
  • DD SS4a & C3d
  • (2) SCV4000 @ .5Ohm
  • (2) 15" Sundown Zv5
Disconnecting ELD will throw a CEL. Bypassing will be more work as I'll need to redo all the wiring to tap into the wires (which I can't confirm if they are the right wires). From my understanding, the ELD bypass fake an electric load to enable ELD and kick in the alt. Similarly, I was able to do that with just turning my headlights on before. Now turning the lights on doesn't help at all. In fact, it work the opposite as it draws a bit more current and alt is not producing shit to help. I might try to pull out the ALTC to see if that will help.
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
Just started to act up last week. I always have my headlights on so voltage had been pretty steady. And there has not been any changes to the system or the car... well besides new tires :D
I do the same thing with my air, if I am driving, I have to turn my air on if it is still to bright for lights in order to have a good voltage and bump.
  • Soon To Be
  • '04 Ford Escape
  • Pioneer DEH-80PRS
  • *Tweeter Unkown*
  • DD SS4a & C3d
