Did you read what I posted above? You are overthinking this way too much.
The dd-1 detects a signal. That's it. It doesn't matter if it is in phase or 180 degrees reversed. All it sees is a sine wave. In some amps, the signal will come out of the negative terminal instead of the positive one. It's just a design. You don't need to do anything special like reversing your polarity because the manufacturers have already accounted for this. Just wire your speakers up like normal.
If you like the way your setup sounds now after you tweaked with the polarity, that's something different. But to wire everything up in phase all you need to do is wire + to + and - to - lol. Don't over think it ;)
It says in the manual to check the negative if you get no signal from the positive.
Well ill switch it back and take a listen. I did the 1 thing your not supposed to do when testing audio..... I changed more then 1 variable. Lol...
I changed the volume point on my headunit to a known cleaner signal, I changed my gain settings to match my new deck level, and I changed the polarity of 2 of the channels according to the DD1.... So I guess I should switch between on polarity and off polarity and take a listen to pink Floyd the wall, and maybe some Michael Jackson (my go to SQ songs) lol
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
If it comes out of the negative how does that effect passive crossovers??
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
If its any consolation.... Lowering from 60 - 56 resulted in way better everything. My doors are louder, my upper mid bass doesn't distort anymore where I used to hear it slightly. And the bass.... Omg... The bass is stupid loud now.
I think it has to do with the dd1 finding distortion due to my improper level on the headunit, so my gains were lower then they should have been.
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
Not sure but I had everything hooked up positive to positive negative to negative.... I even double checked my RCA's and used my fader balance to make sure fading right went to the right side front and back and I also did the same for front to back to make sure nothing was mixed up
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
