Wicks Posted April 30, 2013 Report Posted April 30, 2013 OK lets see what we can put together. Here is a great demo pic of what's going on: POSITIVE is your battery voltage. RL1 is the leakage resistance of the first cap. RL2 is the leakage resistance of the second cap, and so on... RB1 is the first balancing resistor that you would add. RB2 is the second balancing resistor that you would add, and so on... The Maxwell spec gives a ballpark maximum leakage current of about 5mA. With an applied voltage to each cap of about 2.4V, that gives 2.4/5mA = ~480 Ohms which is technically internally across each cap. RB1 is in parallel with RL1 so for the voltage drop across RB1 to take over, the resistance of RB1 needs to be lower than RL1. In the same manner, the current through RB1 needs to be higher than the leakage current through the cap (~5mA). I like to think of it this way: If two resistors are in parallel with R1 being 5 Ohms and R2 being 1M Ohm, then R2 will barely affect the circuit and almost look like it wasn't there. Take R2 to 100M Ohms and it is so close to holding your ohmmeter probes in the air that it wont affect the circuit. In fact the resulting resistance of the two (5||100M) is 4.99999999999 = No affect. Now if you go the other way and lower R2 to 1 Ohm then it is the dominant resistor. (5||1) = 0.8333 Ohms. Back to the topic. Here's a good article: http://www.nmr.mgh.harvard.edu/~reese/electrolytics/ Scroll down to the section on series connected capacitors. They state that the balancing current should be 10x the leakage current. If so then the current through RB1 must be ~50mA or higher. That gives a resistance of 2.4/0.05 = ~48 Ohms. Power in that resistor would be 0.05^2*48 = 120mW which isn't too bad. Your total parasitic draw would be 50mA + 5mA (cap leakage) = ~55mA. With a ~100AH battery at a draw of 55mA you'd have a capacity of ~1800hrs (not counting other draws on the battery). Not sure if you saw it, but here's a paper from Maxwell themselves: http://www.maxwell.com/products/ultracapacitors/docs/an-002_cell_balancing.pdf In it they state that balancing with a 10:1 ratio could take hours so you may need a 100:1 ratio. The higher you go, the better the balancing will be at the expense of higher parasitic draw. Ultimately this is all theoretical and up to you how you want to implement. If it were me and my equipment, I'd contact Maxwell directly and give them your scenario and have their tech experts give you a recommendation. Just tell them you dropped "$XXX" on a bunch of their 3000F caps and would like a recommendation on how to implement them in you car. Informing companies like this that you bought a bunch of their product always helps get a better response then somebody just asking a question. Keep me posted on where you go. I'd be interested in what they say or what direction you take. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
SnowDrifter Posted May 1, 2013 Author Report Posted May 1, 2013 Wicks... You are AMAZING. Like.... Seriously.... That was extremely helpful. I appreciate it I called up Maxwell today and they suggested a 26 ohm resistor as per their 10:1 ratio. Radioshack didn't have any 25 ohm ones and they didn't have enough 50 ohm resistors to parallel them. So for now I'm using 50 ohms for a 5:1 ratio as my starting point. I'll be checking each cell with a multi meter periodically and adjust as needed. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Raptorman Posted May 1, 2013 Report Posted May 1, 2013 My brain is full of fuck just attempting to read this shit. 1996 GMC Sonoma Four Fi BTL Neo 18's In 2:1 6th Order Bandpass 2 Ampere 5k's @ .5 TEAM FI TEAM #LITHIUMCANTDEMO On 10/20/2013 at 0:37 AM, KillaCam said: Fucking with a Prius driver is like making fun of a disabled kid. Pussies.
SnowDrifter Posted May 1, 2013 Author Report Posted May 1, 2013 My brain is full of fuck just attempting to read this shit. It's not too hard to understand. You just need to take a different reading style - typical skimming doesn't work. You need to read it line by line and only go on to the next once you understand it. If you skip something or skim, you will get lost. It's just a matter of looking at the whole picture in detail ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SnowDrifter Posted May 8, 2013 Author Report Posted May 8, 2013 Quick update on this: The 50 ohm resistors seem to do their job. The difference between the caps with the highest and lowest reading is .04v. So... Mission success I'm going to go outside and measure the current draw of the bank in an hour or so. I put my car on a charger and I'm giving it a couple hours to settle and equalize so I get a decent reading ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Wicks Posted May 8, 2013 Report Posted May 8, 2013 Awesome news! That would be interesting to compare the current from the caps vs the Alt/batteries when the amp(s) hit. Although I don't think a normal clamp meter is fast enough to give you a real answer. This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
SnowDrifter Posted May 8, 2013 Author Report Posted May 8, 2013 Awesome news! That would be interesting to compare the current from the caps vs the Alt/batteries when the amp(s) hit. Although I don't think a normal clamp meter is fast enough to give you a real answer. I seem to recall something about D'Amore coming out with one of their LED style shunt meters. But I can't find it on their website. And I measured parasitic draw with the car off. Came back with .06a, which is about what I expected. Nothing big. Enough to make my resting voltage go from 15.15 down to about 14.9 after sitting for a day and a half. Given how much time my car spends on the charger though I'm not concerned. It's just something to keep in mind if the car should sit for a week or more ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
Wicks Posted May 8, 2013 Report Posted May 8, 2013 Yep, the AM-1. I saw it also but yeah, it's disappeared now. I was thinking about getting one myself. Would be handy to have an accurate view of the current draw. Sounds like a small price to pay (parasitic draw) vs the benefit from the caps, that's for sure. Especially if you're charging your batteries like you said anyway then it's no trouble. As long as it doesn't sit too long. Tried thinking about a way to avoid that but there isn't a clean solution. You could disconnect the cap bank by a large solenoid, relay or switch but the extra resistance and whatnot would just take away from the caps. Hmmm, one solution............more batteries and/or caps! This post sent with 100% recycled electrons. 2004 BMW M3Mechman 280A 2 - XS Power XP30001 - XS Power D375 500F of Maxwell SuperCaps (soon to be 1000F) iPadMini2Dash mounted O-scopeAudison bitOne (Remote DRC MP) Highs Amp - PPI Art A404 Hertz HSK130 (HSK165 waiting...) DC Audio DC9.0K 2- DC Audio XL12m2LEGAL - 147.3dB @ 41Hz OUTLAW - 150.2dB @ 45Hz OUTLAW - 145.7dB @ 30Hz JUNE 2014 SOTM WINNER 2014 COLORADO PEOPLE'S CHOICE WINNER SOTM BUILD:http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
SnowDrifter Posted May 8, 2013 Author Report Posted May 8, 2013 HahaIt's not even a big deal. Even if my car sits for a couple days it's not that much of a discharge from the battery. It's less than it was when I pulled it out of the box from sitting in storage lol. I'm not concerned about it unless the car sits for 5+ days It's funny.. The caps will hold their voltage for about 45mins to an hour before they drop to 15v after I'm done driving the car. So even if I make a short trip, that backfeed into the battery helps to make sure it's as topped off as much as it will be without a charger. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
