Cell balancing? Any idea?
I've heard of using cell balancing for batteries (like the li-ion in your laptop) but I only just now read about using it for capacitor banks.
Google didn't turn up much info.
Is this something that is needed/beneficial? And if it is: does anyone have a link on how to build an equalization circuit?
Used to balance cells back when I raced rc cars. helped a lot with battery life, faster recharge time and less heat, small but noticeable performance gain. Not really sure if cell balancing would apply itself in this situation but i would say its worth looking into.
http://www.mpoweruk.com/balancing.htm
BMW 325i Kenwood KVT-647DVD
re xxx components
re 6.5 FR's
2 RE XXX 12's
2 US amps MD3D's
2 batcap 4k's
That's actually where I got the idea haha. I'm really not sure if I need one or not... If I do I don't want to risk the lifetime of my caps by not using one. But if I don't: well... Than I guess that's that.
They are used to ensure that all the cells have the same charge level so they don't get overcharged or over-drained, correct? Capacitors don't have that lifetime that typical li-ion cells have, so I'm questioning if there is a need for one. I can't seem to dig up much on Google either.
And looking into balancers a bit more: I'd really want one that I can just plug and play. I can find the circuit diagrams on Google but they are a bit over my head in terms of what I have the skill to build. All the pre-made ones I've searched for are for lithium ion/polymer batteries. So I'm really in a tough spot right now.
Tony? Ed? Want to come to the rescue here? Lol
I just stumbled across this: using balancing resistors.
The only thing I'd be concerned about is leakage current with the car off. Hmm....
http://www.coilgun.info/theorycapacitors/capacitors2.htm
Cell balancing does help CAPS that are connected in series. It protects from over voltage and extends life.
Using a passive cell balancing (resistors) on a bank of caps when connecting caps to batteries can create a slow drain on the batts.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
That makes sense
How big of resistors would I need? I've found this equation but I don't deal with this stuff often, so I'm unsure of what numbers to put in. Is it the capacitance of an individual capacitor or the entire bank?
For 2 capacitors in series: R = (2Vm - Vb) / (0.0015 C Vb) For N > 2 capacitors: R = (NVm - Vb) / (0.0015 C Vb) where R = resistance in megohms
Vm = max voltage you'll permit on either capacitor
Vb = max voltage across the entire bank of two (or N) capacitors
N = number of caps in series
C = capacitance in microfarads
Since I have 7 paralleled pairs wired in series: Would it be this?
R=(7*2.6 - 16.6)/(0.0015*850,000,000*16.6) - capacitance of bank
R= .756 ohms
Or this?
R=(7*2.6 - 16.6)/(0.0015*6,000,000,000*16.6) - capacitance of a capacitor pair
R= .107 ohms
Or maybe this?
R=(7*2.6 - 16.6)/(0.0015*3,000,000,000*16.6) - capacitance of an individual capacitor
R=.214 ohms
You'd want this version (the resulting capacitance in each series location):
R= .107 ohms
Although check your calculations, I get 0.0107ohms.
Regardless that resistive load is way to low for practical use, even with 7 in series.
I'm guessing the leakage current expression in that formula is off for these large caps.
Reversed-biased Zener diodes are commonly used as voltage clamps/regulators.
You should be able to connect seven ~2.4V Zeners in series and use that.
They'd also have a very small reverse current too so the parasitic draw would be small.
You'd have to check some calculations to see what it would be though.
I'll check more into it.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
So, forget my previous comment on the zener's.
http://www.instructables.com/id/Lets-learn-about-Super-Capacitors-A-Practical-G/step7/Balancing-Your-Series-Banks/
They're good with low power circuits, but wouldn't work when dealing with hundreds of amps of current.
The best person to comment on this would be Tony D as he used a ton of ultra-caps in the T15K.
Although his power supply probably takes the balancing in account and charges each level of caps separately.
Sounds like you either put up with a good amount of waste in balancing resistors or go with an expensive active solution.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Is there any way to calculate this based off the leakage current? Each cap is 5.2ma
  • Who's Online   0 Members, 0 Anonymous, 2075 Guests (See full list)
