Big 3 upgrade on the dakota
Keep in mind the pcm controls the voltage to a set point of around 13.7V max. There is a kit to bypass the pcm, it comes with a voltage regulator as well. It will get you up to 14.5V. It's around 50 bucks.
yeah you can buy kit I saw it was adjustable from 13-15v it was only $30
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
Add a ground directly on the frame itself, that's sheet metal you grounded to.
Upgrade that battery to an agm battery that will fit there.
11 volts maybe better than 9 volts, but it's still stressing the amp, you need a better battery so you keep above 12v.
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
sheet metal na thats thick metal that goes to the fram and I got it going to the block and yes I wish I had an agm battery and a 170alt to but when you don't have the money can't get it.
2 sundown sd-2 d4
flex tech
box design by Joe X
  • Who's Online   0 Members, 0 Anonymous, 2513 Guests (See full list)
