Big 3 upgrade on the dakota
finally did the big 3 on the truck let me tell you before it will drop to 9v in the vide its around 11v much better here a video of it
02 dodge ram 1500 reg cab 3rd gen
2 sundown sd-2 d4
soundstream rub1.2500 amp
all sky high car audio-fuse,fuse holder,wire,ring lugs and rca
flex tech
box design by Joe X
supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch
04 5.7l hemi motor swap and made it an slt eletric everthing
youtube channel-http://www.youtube.c...43?feature=mhee
http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
why are you letting it drop that low?? that puts so much stress on your electrical you don't even know. dropping below 12v = bad
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
because I only have a stock 90 amp alt that sucks and yeah I know its bad but did the big 3 help a lot it used to drop 9v now it more stable at 11v.
2 sundown sd-2 d4
flex tech
box design by Joe X
  • 2 months later...
You will only get 13.7V max, out of that electrical system. Have a 2002 Club Cab dodge dakota. You must have the Denso alt. as well. However mine is a 140A. Cheapest way out of this is go to the Junk Yard, and find the 140 amp alt. and buy it for around 30 dollars:).
stop stressing the fuck out of your electrical system (and the amps) by letting the voltage drop that low.
seriously.
stop it.
if not, you better like spending hundreds of dollars on new equipment.
I've got a 97 dakota with a 138a alt. I've noticed lately it only charges at 13.8 but that's wired into my HU instead of amps so its a little more stable. I drop to high 11 low 12s full tilt idle. Dakotas kinda suck to do big 3 on. Atleast mine did. Not much room for running wire.
My SPL to SQ Build Log
Vehicle:
1997 Dodge Dakota Ext Cab 4x4 2009 Dodge Journey SXT
5.2L V8 Magnum 3.5L V6
Stock Alt
Equipment:
Headunit- Alpine CDE-147BT
Mids/Highs Amp- JL Audio G6600 Class AB 6 Channel
Sub Amp- Hifonics BRZ1700.1D @ 2 Ohms Taramps DSP3000.1D
Sub- Hertz Hi Energy 12" HX300D SounDrive SDA3 12
Tweeters- Rockford Fosgate Power Series Silk Domes Hertz Hi-Energy
Mids- Dayton Audio Reference 4" Full Range Drivers
Midbass- Silver Flute 6.5" Hertz Hi-Energy 6.5"
Processor- MiniDSP 2x4
RCA- 6 channels of SounDrive HF series
Wire- EB Flex 2/0
-Member of Team SounDrive
Now add you another battery. That should help too. Lookin good so far.That some thick azz wire bro.
na I don't need another battery but I like to get a better one under the hood its only 1000rms I just need a 170-200amp alt
2 sundown sd-2 d4
flex tech
box design by Joe X
can get a new one for $40 with lifetime warrant because the alt I got now as a lifetime so I just swap out and pay the difference
2 sundown sd-2 d4
flex tech
box design by Joe X
Keep in mind the pcm controls the voltage to a set point of around 13.7V max. There is a kit to bypass the pcm, it comes with a voltage regulator as well. It will get you up to 14.5V. It's around 50 bucks.
  • Who's Online   0 Members, 0 Anonymous, 1270 Guests (See full list)
