shepherd92683 Posted August 29, 2013 Author Report Posted August 29, 2013 I suggest that you take a close look at the factory negative cable for the hall effect clamp I speak of. If you have ground cables that do not pass through this clamp, that could explain your problems. I have searched for info on this and get nothing that helps. Is there anymore detail on where it is or anything that would be helpful in telling if my vehicle has one? 2017 Honda Accord Touring Build coming soon
shepherd92683 Posted August 31, 2013 Author Report Posted August 31, 2013 2. If you have an '08, it should be a PCM/RVC controlled alt right? Try this for me, next time it starts to drop in voltage while driving, turn your headlights on, not just the DRL, but use the rotary knob on the column to turn the lights on. I tried this. It didn't seem to have any consistent effect. More often than not it would make the voltage kind of stabilize then after a few minutes, it would go up .4-.8 but not every time. I also tried turning the a/c on and off to see how it reacted and it was a -.1 or -.2 when turned on and immediately back up when off. My next task is moving my ground on my rear battery to the frame. That will wait til its not over 100 degrees out and I've not worked a 12-13 hr day. Haha 2017 Honda Accord Touring Build coming soon
shepherd92683 Posted September 1, 2013 Author Report Posted September 1, 2013 Could it be that my 2 batteries are not sharing a common ground is what's causing it? One on the chassis and one on the frame? 2017 Honda Accord Touring Build coming soon
kandiman71874 Posted September 1, 2013 Report Posted September 1, 2013 I suggest that you take a close look at the factory negative cable for the hall effect clamp I speak of. If you have ground cables that do not pass through this clamp, that could explain your problems. I have searched for info on this and get nothing that helps. Is there anymore detail on where it is or anything that would be helpful in telling if my vehicle has one? it looks like a plastic encased magnet that is around the battery cable up by the battery. you cant miss the damn thing. Daily Driver 1999 Kia Sephia Kenwood DNX-893s Audison Bit One Processor 2 Dat 4.125's Sundown Audio SCV-6k Hertz hsk-165xl's Mids running active Focal V30 Series Tweeters running active Sundown Sa-8 v1's in the doors 2 Sundown Zv5 12's Lots of Hushmat Big 3+ and 3 + & 3- runs of Trystar 2/0 2 Dc Power Engineering 320 HP Alts 2017 Comp Vehicle 2006 Toyota 4 Runner Kenwood Excelon DNX-893s Audison Bit One HD DSP 4 Sundown Sa 6.5v2 Component Sets Focal Access 6.5 2 ways Sundown Audio Sax-50.4 Sundown Audio Sax-100.4 2 Dc Power 370xp Northstar agm27f Northstar agm65 2 Northstar asmagm 480's 2 Dual 1 Sundown Nightshade v3 12's 2 Sundown SCV-7500's All SMD Fuse Holders Shitload Of Sundown 1/0 120 sq ft Second Skin Damp Pro No, Its Not A Burp Truck!!!! 2016 Season 3rd place in Xtreme 1 At Finals 2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations) 2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL David said: audio is a lifestyle, not a hobby newls1 I cant read a tape to save my life... 1/2's are ok, but other marks confuse me kingsuv only men who cant read a tape, take it in the ass kingsuv you sir, get a pink hard hat on jobsites
shepherd92683 Posted September 3, 2013 Author Report Posted September 3, 2013 I ran the ground through the hall effect clamp It peaked at 14.4 momentarily and then slowly dropped. This was the steady voltage result after initial start up. This is driving me crazy! No I dont have a VM-1, yes I wish I could replace the Stinger and yes the Stinger is calibrated as accurate as can be lol 2017 Honda Accord Touring Build coming soon
Karkov Posted September 3, 2013 Report Posted September 3, 2013 That's the sensor. You should have a ground running straight from alt to first batt, then connect all other batts negatives to the first batt, even if you go one by one by one. DO NOT add any additional grounds or ground things to frame or body. The sensor senses how much current is going through that ground wire so when you add grounds it doesn't know to have the alt ramp up output power. Essentially you want that sensor to read the negative side of everything in vehicle. I ran ground from alt through sensor to first batt, then another from first batt to second, then to third etc. Then grounded amps to batts negative. If you do anything different you could, and most likely WILL see voltage issues. 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
shepherd92683 Posted September 3, 2013 Author Report Posted September 3, 2013 DO NOT add any additional grounds or ground things to frame or body. Not looking to argue here, but that is part of a big 3 upgrade. I cant see why I wouldnt want to do that, but I ultimately need help in my situation so I am here to get any and all info to help. I also am not doing a run of 1/0 to my rear battery. With the amount of power I would ever run, I dont see the benefit of it. One thing that is strange to me is I ran these wires (big 3) well over a year ago and instantly noticed a 1v increase. Only as of the last few months have I noticed the voltage issues. The only thing I can imagine is like Karkov said and the alt is not ramping up to output more power. But why is that happening out of nowhere? It used to run 13.2-14v all day at full tilt. 2017 Honda Accord Touring Build coming soon
Karkov Posted September 3, 2013 Report Posted September 3, 2013 Can't do a full big 3 with that sensor. Why voltage changed now I have no idea. What size do you have to your rear battery now? i don't care what size you run to back lol. the reason for not wanting additional grounds is because you want that sensor to read all current so that your alt runs to keep up with demand 1:1 and not have things getting current through other grounds instead thus having your alt putting out only 60% (give or take of course) of what it actually should. Big 3 isn't a cure all that everyone do do in every vehicle. 2005 and newer GM vehicles with the sensor can't just do the regular big 3 and call it a day. I really can't help you with your problem, I only know about that sensor thing. If I was you I would remove all grounds (just unbolt one end of themhave wire in place not touching anything) and see what voltage then does. If your voltage is crap either alt is going bad,or battery is not holding charge well. have you ever topped off your batteries over night? 2007 Chevy Tahoe (SOLD) 12 ~ FI Audio X series 10" w/BP option 2 ~ DC Audio 5.0K @0.67 3 ~ DC Audio 5.0K @1.0 2 ~ PPI 3 way sets (not installed yet) 1 ~ RF T400-4, 1 ~ RF T600-2, 1 ~ RF T600-4 4 ~ CT Sounds 5.25" Strato comps (rear fill only) 1 ~ XS Power D4800 1 ~ XS Power D3400 8 ~ XS Power XP3000 160 stock alt, Mechman 370 Elite, 185 DC Power 320+ Sq. Ft. Sound Deadener Pioneer AVH-X5500BHS Youtube: https://www.youtube.com/user/knfjdkghjudfhsgkjdhf/videos?sort=dd&view=0&shelf_id=0
shepherd92683 Posted September 3, 2013 Author Report Posted September 3, 2013 As a test, I did undo the run from the batt - to the frame and no change. I have 1/0 on everything in the vehicle. I have topped off my battery's overnight. I have a Battery Tender Plus to do that with but I do need to do that again here soon. If this is a common issue on GM vehicles, surely there is a thread somewhere on SMD about it. I dont think I would be the first person to have this problem. If there is a different method of doing the big 3 than what is conventional, I'd like to know. I think my next effort will be removing my ground connection from my rear battery so see what happens. Thanks for the help Karkov. 2017 Honda Accord Touring Build coming soon
shepherd92683 Posted September 3, 2013 Author Report Posted September 3, 2013 After removing power to my rear battery, the voltage stayed .3 higher. Would that mean that there is a weak link in the rear ground? I still need to move that ground point as I mentioned earlier. Need to get a couple 1/0 ring terms before I can do that though. If both batteries are grounded to different locations, can that affect the voltage in a bad way? 2017 Honda Accord Touring Build coming soon
