Box design help.
Yes please.
2002 chevy avalanche
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
Second set of T2652-s
D3100's
deadner
Here is it:
Enclosure Specifications:
Fb = 34.5 Hz
Vb = 3.8 ft^3
External Height = 16 in
External Width = 35 in
External Depth = 19.5 in
Port Width = 3 3/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
2x Front = 15 5/8 x 14 1/2
Back = 35 x 14 1/2
Left & Right Sides: 18 x 14 1/2
Top & Bottom = 35 x 19 1/2
Shared Port Internal Assembly Parts:
2 x Front to Back = 16 1/8 x 14 1/2
2 x Extension = 3 9/16 x 14 1/2
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the car need to fit in their way in not just have the right dimensions.
- The port needs 3 3/4" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
Hey joe would this box work with a sundown z12v3?
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
D3100's
deadner
It would be better a double baffle variant at least, if you expect that sub to sound the same as SA series, only more power handling, that's probably not the case.
Well I doubled the front. Or would I need to double the whole thing?
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
D3100's
deadner
Hey joe what would be the best way to make this a split box. I can't physically fit this box through my trunk. My box for the single 12 barely fit.
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
D3100's
deadner
  • 3 weeks later...
Joe could I split this box some way or make it less wide or tall i can't fit this through my trunk for the duel box design . Stupid civic. Lol
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
D3100's
deadner
Sorry I didn't read your previous post, yes I can work out other dimensions if necessary, just tell me what do you need, I usually recommend building a cardboard dummy box to verify given dimensions will fit.
No worries ill have to build a card board mock up. And is slotted ports better or would I be fine with a round port say 6 inch aero port.
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
D3100's
deadner
  • Who's Online   1 Member, 0 Anonymous, 2887 Guests (See full list)
