Wiring subs to final ohm load of 1.33 - 6 subs
About to rewire so I'm at 1.33..
If I'm correct, you wire
Amp to coil 1 in parrel then from coil 1 to coil 2 in series correct?
Btw they are D4 subs.
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Cool, kicker app is horrible lol.
Thanks broo.
Team Subsonic Lows
alright.. so, this one is wrong correct? and just to make sure, if I put my DMM to one sub not connected to another sub it should read 8ohm right?
Team Subsonic Lows
yea. that's wrong.
the series jumper doesnt need to be connected to the ground like you have it. The jumper itself completes the circuit between coil 1 and 2.
ill edit your pic, give me a min.
I showed two alternatives, both parallel the 3 the same. if the 3 woofers are D4, this gives you a final 2.667 load, connect 3 more the SAME way to the SAME point and it will parallel again to 1.333.
Damn guess I'm rewiring, AGAIN lol.
Team Subsonic Lows
  • Who's Online   0 Members, 0 Anonymous, 515 Guests (See full list)
