4th order port tuning
I have been designing a 4th order for 2 skar zvx 12s I plan on buying soon but I have a question. I have been reading on a thread in here that you want the tuning to be somewhere around 45hz for the ported section. However if I am looking to feel the lows, do I need to tune it lower? I guess my real question is there a way i can find the range of bandwith or hz the subs will sound good at it just bassed on the numbers? Also, based on saying that i want to hit lows, is a 4th order the way to go or should i just do a normal ported box? any help is great.
-05 Chevy Colorado-
Kenwood KDC-352U Headunit
Skar VXI-65 front component speakers
Polk DXi650 rear speakers
Alpine MRP-F300 4 chan.
DC 3.5k Mono block
4 Skar VVX 8 D2's
3 cubes @ 28hz
XS d3400
Big 3
Build Log: http://www.stevemeadedesigns.com/board/topic/165896-05-chevy-colorado-4-vvx-8s-vxi65s-daily-driver/
Bringin' car audio to this half a horse town in Iowa I call home.
4th order's are great for lows. 45hz is pretty good for decent lows, but what do you consider low? I believe 45hz will get you down into the high 20hz range, like 28hz 29hz
2000 Dodge Durango
Subs - (2) SKAR VVX 15 D2's
Box - 7.2 ft^3 @ 33hz, 120 in of port
Sub amp - Digital Designs M2 @ .5 ohm
Mids + Highs - PRV Audio
Mids + Highs amp - Hifonics 2000.4
Headunit - Alpine CDE-100
Equalizer - Clarion EQS746
Batteries - Mopar group 27 + (2) C&D 52ah
Wiring - 1/0 BIG 3, (2) runs 1/0
Alternator - Singer 250A
147.79 dB @ 35hz - burp - sealed on dash
147.47 dB @ 35hz - music - sealed on dash
YOUTUBE: http://www.youtube.com/user/321slapinBass/videos
What ratio are you planning on using for the box? 45 is actually on the lower end of what you would normally tune a bandpass to.
[sharedmedia=garage:vehicles:2223]
CAFForumSig_zps376518ed.jpg?t=1364077982
SD, thank for the input. I would have replied earlier, but I was measuring the output of my amp with a yardstick . . .
idk im just used to tuning normal ported boxes like 28hz-32hz but i didnt know how this would compare. the dimensions and ratio thing i get, but the bandwidth and hz part is confusing me a bit.
-05 Chevy Colorado-
DC 3.5k Mono block
4 Skar VVX 8 D2's
3 cubes @ 28hz
XS d3400
Big 3
The ratio will determine your bandwidth. The higher the ratio the smaller the bandwidth, and vise versa.
awesome guys. thanks. Ill just stick with the 45hz then :)
-05 Chevy Colorado-
DC 3.5k Mono block
4 Skar VVX 8 D2's
3 cubes @ 28hz
XS d3400
Big 3
For most output with ok frequency response the 3:1 will be good. if you want to scare the crap out of people and hit the lows, go with 45Hz and your 3:1 ratio.
I'm in for results.... I love 23 hz personally. After about 50 hz Idc for it as much. I think I'd rather have my sub stage play 20-50 hz like a beast and then have a small 8 or some bad ass mid bass speakers for the rest of the notes because I don't like those upper notes to be head cracking
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
  • Who's Online   0 Members, 0 Anonymous, 451 Guests (See full list)
