Need to break 150db, need box ideas
Hey guys...
Here is the deal...
I need to get into the 150's at the dash
Equipment:
2 x DD 9510
1 x DD M4 (~5K)
2 x Yellow top Optimas in the boot
This wil run a test tone
I need advise as to the optimum SPL boz size / port size and turning frequency...
Also do I build to same size boxes or one box for both subs
I built 2 x boxes according the DD's website but they look too small for max SPL
The other variable is the car...
We are sharing this project between a few of us...
Cars:
2007 Merc ML320 SUV
2007 Merc CLK63 Coupe
Mazda Mx6 Hatchback
EK Honda Civic hatchback
I think the euro cars can do well as they have excellent insulation and minimal leaks, but hatchback are
hatchback and are great for SPL...
With a hatch and a M4a you should be there in no time.
You have the car, the power, the motorforce, maybe not the cone area. But the right box you should be there .
I had 2 dd 9510s at 3.4 cubes tuned to 34hz doing 144s daily in a trunk car with 3k .
Goodluck
the hatchbacks are definitely the best option here, i would do something like 2 cubic feet and a 8" aeroport if you can fit it, and i hope that amplifier is wired at .5 ohms or less, if not, is gonna get more difficult to get a 150 wired at 1 ohm
Well I made the DD recommended boxes 1.5 cubic feet each... but they look too small... that said, according to you guys thay should be fine...
I cant wire them to 0.5ohms as they are Dual 4ohm so I will run them as 1ohms which is the lowest the amp is stable to...
If you havent built a box yet. Try to do 1 cbft per woofer then port area like crazy. On spl you want a lot of port area. DD's love port area in the first place so they need a ton.
  • Who's Online   0 Members, 0 Anonymous, 1802 Guests (See full list)
