RECKS Posted May 6, 2013 Report Share Posted May 6, 2013 Hey guys I have a quick question, I was wondering if I can use my alarm output for more than one use? For example starter kill, window roll up? Link to comment Share on other sites More sharing options...
Pioneerchuck Posted May 6, 2013 Report Share Posted May 6, 2013 Technically speaking you could in theory use it for 2 different systems. Its basically a switch letting the other systems turn on. So possibly depending on the actual output of your output channel you could get away with it. Link to comment Share on other sites More sharing options...
jmsonoma03 Posted May 10, 2013 Report Share Posted May 10, 2013 what alarm do you have? most have a few outputs! Link to comment Share on other sites More sharing options...
lightfoot Posted May 15, 2013 Report Share Posted May 15, 2013 yes u can. u just have to diode isolate them from back feeding. Link to comment Share on other sites More sharing options...
nickers Posted May 28, 2013 Report Share Posted May 28, 2013 if you get familiar with relays anything is possible with a single momentary negative aux output from the brain of your alarm. http://the12volt.com has a ton of relay diagrams to point you in the right direction. chevrolet all day er day. '81 camaro z28 performance '03 silverado ext cab show and go Link to comment Share on other sites More sharing options...
ac316scu Posted June 24, 2013 Report Share Posted June 24, 2013 Yes. Like everyone else has said make sure you use diodes and relays. I have my alarm hooked up to turn on the strobes in my head/tail lights and all the other emergency lights in my car. I want to see somebody's face when they try to break in and its a light show. Link to comment Share on other sites More sharing options...
20 hertz xpertz Posted August 19, 2013 Report Share Posted August 19, 2013 most systems will have more than one output if yours doesn't then relays and diodes for blocking are in order. "crank it til it hertz" Link to comment Share on other sites More sharing options...
