Isolators? What are they for
Like the title says, I'm wondering how you hook these up and if they're needed if you have extra batteries in the back, I don't have one right now so I'm not sure if that's bad or not
I'm told their used if you mainly play your music with the car off. They allow the alternator to charge the two batteries separate from each other, so if you drain the battery for your system, it won't allow it to start draining the battery that turns your car on. They're fairly simple to hook up, they have 3 prongs, one in the middle for your alternator, then one on each side for the separate batteries. I'm not using one, and my system has been doing fine for the past few months, as long as you be careful not to drain both batteries when the car is off. That's my opinion, it's not really needed for me.
No you dont need an isolator to wire extra batteries to your front battery. Wire positives and negatives together this will add the capacity of the batteries together and still remain 12v.
An isolator is mostly only needed if you play your stereo with the vehicle off until the batteries are discharged. The isolator will keep your front battery voltage at the proper resting voltage so you can still start your vehicle up again whereas the other batteries will be low voltage and need recharging.
useful if you play music with the car off (for some reason) and want to be able to start your car. thats about it.
I only listen to mine off if I am camping. I have my headunit wired so I don't need a key to turn it on. But I turn off my sub amp and just listen to my mids...usually pretty quietly. IMO it would be stupid to run a system full tilt until your batteries were so depleted the stereo/amps shut off, can't be good for amp or battery health.
MY BUILD *****http://tinyurl.com/gmcbuild*****
Vehicles
2005 GMC Canyon
CB1000r - Currently where any future funds are going. (exhasut,bazzaz, ohlins shock, screen, etc.)
crf250r - Used to be race bike..now I just trail ride..practice at the track on it.
CH80 - Daily beater (when nice weather)best 150$ ever spent. 100+mpg
Sold to:
Skullz - pstone11 - Leo1103 - Volvo 63' - pavelpardo - imnew59585
Shower farts still piss me off.
I think theyre pretty neat. When the water runs down your crack as you let one out... its like shitting in a crockpot.
Deep cycle batteries. But even still, I wouldn't do it
Okay, we'll I don't play mine with the car off much so I won't need one, I also heard that it extends battery life, but it seems like it would help extend the life of the front battery but shorten the life of the rear batteries
Isolators don't to anything in the way of extending battery life. Unless you have a bad battery or something that is dragging down the rest. In which case, you would be better off spending the money of a battery to fix the issue at hand vs. installing an isolator ;)
  • Who's Online   0 Members, 0 Anonymous, 2075 Guests (See full list)
