gibblegeibel Posted May 8, 2013 Report Share Posted May 8, 2013 i have 2 12 rockford fosgate p3 the versions that do 500 watts rms and was looking to build a ported box for them what do you guys suggest for size and hz. my max demesions are 14 high 36 wide 16 deep Link to comment Share on other sites More sharing options...
Joshex Posted May 8, 2013 Report Share Posted May 8, 2013 What power are you running them at and what kind of tuning would you want? 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here Link to comment Share on other sites More sharing options...
skittlesRgood Posted May 8, 2013 Report Share Posted May 8, 2013 are those dimensions until you hit a wall or is one of those dimensions open? If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people. Link to comment Share on other sites More sharing options...
gibblegeibel Posted May 8, 2013 Author Report Share Posted May 8, 2013 i have till i hit a piece of the car. and i would like to tune about 40 hz Link to comment Share on other sites More sharing options...
Joshex Posted May 8, 2013 Report Share Posted May 8, 2013 Ok, I made it the max dimensions it could be, so you better test fit with a cardboard cut out to make sure it will fit properly. The box is a bit underrated but should work. Also, I am no expert just to let you know. If someone else wants to chime in and give some suggestions, I would love that. 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here Link to comment Share on other sites More sharing options...
DylanBunch Posted May 8, 2013 Report Share Posted May 8, 2013 Too much port per foot^^try 14 port per foot 2006 Ford Explorer 2 Team AA/Sundown 15s 6th order Ct Sounds 7k 4 PRV Mr500 8s Rockford p1000-2 Team Subsonic Lows Link to comment Share on other sites More sharing options...
skittlesRgood Posted May 8, 2013 Report Share Posted May 8, 2013 two things here. one, that box is fucking tiny. yeah the port should be smaller and that will help BUUUUUUTTTT, he said those measurements were until he hits a wall. so just the subs being on the front of that box means that it wont fit. it goes over the max dimension. but even if they did fit, you're firing a sub and port directly into a wall. there needs to be AT LEAST 4" between the port and a wall. so to summarize... you don't have enough space for two 12"s ported, and you should never take box building designs from a noob. either go with a sealed box or sell one of the 12"s. If I answered you in a well mannered, informative way, you asked a good question or had a good attitude. If I was an asshole, you asked a stupid question or you had a fucktard attitude... or I was in a bad mood. Team BassickHU: Pioneer AVIC Z110Front: Peerless SLS 6.5", Peerless HDS 4", Rainbow tweeter - running activeAmp: JL HD600/4 and DC 4 channel (bridged to midbass)Processor: JBL MS-8Subs: 2x 12" AA MayhemsAmp: DC 3kElectrical: DC power 270xp alt. 1/0 big 4. XSpower D3400 and six D680s. http://www.stevemeadedesigns.com/board/topic/121795-29-update-the-buick-is-getting-a-rebuild/ Top career scores: DBdrag 151.7 MECA SQ 82.25My SOTM build Yeah. im pretty sure they dont warranty retarded people. Link to comment Share on other sites More sharing options...
gibblegeibel Posted May 8, 2013 Author Report Share Posted May 8, 2013 ok Link to comment Share on other sites More sharing options...
gibblegeibel Posted May 8, 2013 Author Report Share Posted May 8, 2013 well the box will be in the trunk of a 2004 nissan sentra 1.8s Link to comment Share on other sites More sharing options...
Joshex Posted May 8, 2013 Report Share Posted May 8, 2013 two things here. one, that box is fucking tiny. yeah the port should be smaller and that will help BUUUUUUTTTT, he said those measurements were until he hits a wall. so just the subs being on the front of that box means that it wont fit. it goes over the max dimension. but even if they did fit, you're firing a sub and port directly into a wall. there needs to be AT LEAST 4" between the port and a wall. so to summarize... you don't have enough space for two 12"s ported, and you should never take box building designs from a noob. either go with a sealed box or sell one of the 12"s. Well, I know the 4" rule, but it's also way easier to design a box if you had all the adequate information or could see everything in person. I personally wouldn't have 2 12" woofers for that small of an space. Takes a lot of planing to get a system to work together smoothly. I would listen to Skittles and take a different approach for your system, make it well planned. 95 Acura Integra - 5-speedNFG Pioneer FH-X700BT(2) Rockford Fosgate 12" P3AQ1200dRockford Fosgate P1652-S 6.5" components Rockford Fosgate P1572 5x7"Rockford Fosgate R400.4 95 Integra Build Here93 EJ2 Build Here Link to comment Share on other sites More sharing options...
