XS Power
Need help on what battery to get
Need some suggestions on what size battery to get I will be running it in the trunk I am running a Rockford fosgate t600-4 pushing t2652-s components and t1693 6x9s along with a alpine mrx-m240 pushing a Orion Hcca 12.4 will be doing a high output alternator upgrade and the big 3 just don't know what size battery is best for what I'm doing
I liked my xs power d3100 I believe the model was. Worked better then my optima yellow top I have now. Wish I never sold it. But needed money.
Current system (still building) 2 kicker 12" dcvr in factory kicker ported box, Rockford Fosgate 1200.1 Amp, Kenwood ddx-470 ddin radio, Rockford Fosgate 0 Gauge wiring, Rockford Fosgate punch 6X8 2 way speakers.
That uses a Group 24F under the hood, which is a reverse terminal of the D2400. You may be able to use one of the new D4700 or D4800 batteries under the hood, but would want to measure and make sure first.
Do u think ill be fine with just upgrading my battery under the hook instead of adding a second battery ?
the wattage chart from XS power says a D4700 and D4800 is good for 2000 watts as main battery and 3000 watts as a secondary battery. say you have 3000 watts ( overshooting), the XS battery would work as a secondary battery but if it was me, id get a D2400 or a D2700 and use it as a secondary. rather have too much then not enough
My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/
2001 Ford Mustang GT
4.6 SOHC 380HP
270 amp Mechman alt
2 12" Treo SSX custom built.
6.47 cu ft, tuned to 32Hz
2 hifonics Brutus 2400.1, strapped
1 optima yellow top
1 Kinetic HC1800
14.4v @ 29Hz, 2k RPM
over 100ft 1/0 XS flex wire
Big 3 in 1/0
100sq ft fatmat deadener
145.3 on music, 142.6 sealed on music
Stop being a pussy and wall it off.
I hate when my google breaks too
I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
heres the wattage chart from XS power.
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
So just get 1 battery and keep what I have under the hood and use the xs power battery as a secondary ?
thats what i would do if i was in your shoes
4.6 SOHC 380HP
270 amp Mechman alt
1 optima yellow top
1 Kinetic HC1800
Big 3 in 1/0
  • Who's Online   0 Members, 0 Anonymous, 748 Guests (See full list)
