Sky High Car Audio
Step by step how to video: Soldering Sky High's power cable to closed end terminals, pull test page 3
purplesyrup
I do them almost the exact same way, even use the same torch. Only difference is I don't twist the cable after its in the lug. I fill my lug half full so the solder just barely comes out when I shove the cable in. I found that if I dont twist the wire before putting it in the lug, the solder will wick up the wire right to the edge of the jacket. Nice vid
BMW 325i Kenwood KVT-647DVD
re xxx components
re 6.5 FR's
2 RE XXX 12's
2 US amps MD3D's
2 batcap 4k's
Great video bro i will be using this method when my 2/0 comes in tomorrow!! :D
02 impala
VM-1
2 dc 12 xl's
RF t2500bdcp
Second skin damp pro
Kenwood head unit
240 mechman alt
d3400 in the front
d3100 in the rear
50ft Rockford fosgate ofc 1/0
Yeah nice vid man! I like solder over crimping which is why I used open ended rings, but now I want to try this on some SHCA closed end terminals. They also make solder slugs for this situation but your way is just as easy I think a little cheaper as well.
My 03' sierra crew cab Here build in progress
me too, I could never get a crimp to hold like this method. the only way i have been able to get the terminal off the wire is to heat it back up all over again until the solder mets, otherwise, you will damage the cable trying to pull test the soldered connection, because its not coming off, lol
