Sky High Car Audio
Step by step how to video: Soldering Sky High's power cable to closed end terminals, pull test page 3
purplesyrup
Just tried it, I couldn't get the 2/0 in the terminal as easy as you did with the 1/0.
Any recommendations?
I did this a little different but the same, on my VAN. I did the BIG 3 and Ran 2/0 front to rear. I just took my time to get all the wires done right after a mess up or 2. I'll never do it differently again
Does this smell funny to you? Its your sister :roflmao:
twist the end of the wire, then use a terminal to twist the wire into it and spin it around the wire for a sec, that will form the wire to be ready to twist into the terminal filled with solder, i hope that makes sense,
Could also shave a little bit of wire off if necessary.
2012 Jeep Wrangler 3.6 W/ 6 Speed
Build Log
2011 Ford F-150 SVT Raptor 6.2
Build Log
YouTube
  • 2 months later...
  • 1 month later...
Time to try it on 4 gauge. Thanks purp.
Works great :P I had a run set up to put in but turned out it ran somewhere else. The 1/0s solid though
No problem, I have done this method on 1/0, 4, and 8 gauge, all great results.
What torch is that and how much was it and where can I buy it?
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
