wire from alt to rear batt vs front batt to rear batt
I like both....
A run to the front, and a run to the rear bank....
Pick your poison ....
funny you say that cause this post made me think about that, one to front bat then back to back batt bank then amp other run straight back to rear batt bank then amp, not sure if any benefits though
There may not be any true ones.... If your connections are legit, a run to the front bat, and then from there to the rear should suffice... That said,... If im running a 375 amp alt, i want it doing every damn bit it can,... NO restrictions... NONE.....
IIRC They recommend alt to front bat to rear bat.... because most cars have a 175 amp factory anl fuse between the front bat and alt. Which is refereed to as the mega/maxi fuse. Usually located on the side of the fuse box.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
so front batt to rear batt. soinds like what most ppl are doing. anybody saw that thread somebody started saying alt straight to amp? whats up with that
B2 Zero.7r - Soundqubed 4-120 - Digital Designs 9918 - Rockford Fosgate T1 5.25" - Deh-80prs - XS Power D3400 XS Power XP3000 - Mechman 250A - Big3
  • Who's Online   0 Members, 0 Anonymous, 1316 Guests (See full list)
