Box design for ram
I need a box design for rockford p3s to go behind his seats. He can go 59 wide 17 tall and depth of 9 inchs.
I checked and it can be done 19 x 59 x 9.25.
that would work 4.51 cubes to start with
After ports and subs displacements it gets to about 3.9 cubes net which is ok.
Could you please sketch that up for me joe.
2002 chevy avalanche
Currently have:
2 dc xl 18
set of T2652-s
scv-6k
Ct sounds 75.4
270a mechman
xp3000
d3400
Wanted:
saz 200.4
Second set of T2652-s
D3100's
deadner
Here is it:
Enclosure Specifications:
Fb = 34.2 Hz
Vb = 4 ft^3
External Height = 19 in
External Width = 59 in
External Depth = 9.25 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 59 x 19
Left & Right Sides = 7 3/4 x 17 1/2
Top & Bottom = 59 x 7 3/4
Port Quantity and Dimensions:
Number of Ports = 3
Pipe Port Diameter = 4
Pipe Port Length = 19
External Length = 5
Assembly guide (generic dimensions):
Important notes:
- The 45s if you want to do them are 2 1/2" wide except the one/ones inside the port, if you want that let me know.
- All boxes built outside the car need to fit in their way in not just have the right dimensions.
- This box should be operated around subwoofer(s) rated power. If that´s not the case, let me know.
- The port needs 0" of free airspace in front of it for proper operation.
- Setting your amp subsonic filter to 28Hz is suggested.
  • Who's Online   1 Member, 0 Anonymous, 778 Guests (See full list)
