Stevieboy626 Posted May 12, 2013 Report Posted May 12, 2013 Putting it in a truck. Not sure what box to go with. Any ideas?
Omega5002 Posted May 12, 2013 Report Posted May 12, 2013 I don't think HCCA's even like sealed boxes 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Stevieboy626 Posted May 12, 2013 Author Report Posted May 12, 2013 I want a tight clean bass. Specs say sealed for sq.
Guest Posted May 12, 2013 Report Posted May 12, 2013 I want a tight clean bass. Specs say sealed for sq. proper ported box > sealed box. i cannot see that woofer working half decent in a sealed box.
Omega5002 Posted May 12, 2013 Report Posted May 12, 2013 I want a tight clean bass. Specs say sealed for sq. A properly designed ported box will provide that as well 2003 Kia Sorento Team Subsonic LowsTeam Bassin' on a Budget2016 Rebuild Under Construction Best score: 150.2 at 40hz (3k, 2 Custom HDC3 15's) Usaci style(door open, in the kick)
Quiet Posted May 12, 2013 Report Posted May 12, 2013 Then go with spec if you already know what you want. I'm not a big fan of acoustic suspension... its like throwing away half the sound by keeping it locked up, and you're completely sacrificing low end extension too. If you have a vented enclosure that isn't transient then you're doing it wrong. Most people say that about ported because they're using the wrong box, like a prefab. 2007 Pacifica Rebuild. Less quiet. Still not loud.
OrionStang Posted May 12, 2013 Report Posted May 12, 2013 HCCA and sq in the same sentence, LOL. SMD Super Seller My Feedback Thread
Quiet Posted May 12, 2013 Report Posted May 12, 2013 And overdriving a sealed box sounds a lot worse than a vented. I say sealed only if you don't have room for a proper ported and you don't want it loud. 2007 Pacifica Rebuild. Less quiet. Still not loud.
dfoland93 Posted May 12, 2013 Report Posted May 12, 2013 ported The spot with least resistance LOL. I would ground to a rubber dildo if it had less resistance than a run of 4/0 wiring. how many poeple work there 3 or 4 lol At crescendo HQ? probably 2-3 At the sweatshop in china? 30,000 children No Engine
