N9neMillahhh Posted May 16, 2013 Author Report Posted May 16, 2013 He knows what he's doing and he's kind of a stuck up prick so he wouldn't dare to clip his stuff... 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX
Emmet Posted May 16, 2013 Report Posted May 16, 2013 He knows what he's doing and he's kind of a stuck up prick so he wouldn't dare to clip his stuff... Stuck up pricks are usually the ones who won't admit they have no idea what they're doing. i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah.. You want this to happen to you? Give decent handshakes people. I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Aidan Hansen Posted May 17, 2013 Report Posted May 17, 2013 So if I got a Mechman that's 270A and run however many inputs on the amp I need, like if it has two sets of power inputs I'll run both sets of runs, and a new hood battery, and possibly a second battery in the trunk, would that be a good set up? Big 3 of course too. All in sky high 1/0 gauge. If you go with their ofc I'd say yes you'll be fine. IMO if using cca I'd use dual inputs. Not saying you need them just will help your amp allot if you do. ^Vehicle log to come soon for this.^
chad190 Posted May 19, 2013 Report Posted May 19, 2013 I only plugged in the numbers from the site, i wasnt saying that's exactly what he'd be getting.. it never hurts to have an alt bigger than what you need 2006 Monte Carlo Pioneer DEH-80PRS 2 SSA ZCON 12's 5 Cube Box tuned to 32 Hz Soundqubed 3500.1 PAC LC-1 Singer 320 Amp Alt XS D3100 & Kinetik HC2400 in trunk Super Start AGM Under Hood 80ft+ Sky High 1/0 40 ft^3 120mil sky high deadener Soundqubed Pro Audio 6.5" mids Soundqubed Super Tweeters Alpine 1" Tweeters Alpine MRP-F300
N9neMillahhh Posted May 20, 2013 Author Report Posted May 20, 2013 So would a 270A Mechman be the right choice then? 02 Lexus IS300 (2JZ FTW) Mids/Highs: JL Audio C5 6.5s all around Mids/Highs Amp: JL Audio HD 600/4 Subs: four SA-8v2s in 3.8cubes @ 32hz Sub Amps: SAZ3k Battery: Huge Interstate Batteries relocated to trunk About 80ft. of 1/0 OFC.... Head Unit: Pioneer 4200NEX
bSems Posted May 22, 2013 Report Posted May 22, 2013 P(W) = V(V) × I(A) power in watts is = to volts times amps so re-arrange it to power/volts=amps 3500(watts)/(14.6Volts)= 239.73 AMP so to answer your question, a 250 amp alternator will be sufficient, yessir EDIT: unless you're running at 16V, which would be crazy. but if you were, just plug it into that equation, which would be : (since the site says it does 5300 @ 1 ohm on 16V) you would do: 5300/16 = 331.25amps.
bSems Posted May 22, 2013 Report Posted May 22, 2013 long story short since my last post shit itself. A great % for amp efficieny is 80%. So if you want 3500 watts... then you supply a system that capable of giving 4375 watts. Divide taht by the voltage you sit at WHILE playing your music at your normal listening level. I say use 13.XX volts to give yourself playing room to add amps in the future. 4375/13=336A. This is your target amperage bank.. whether you use alts or batteries to get there, is all your choice.
