Is this good enough to support my amp and maintain 14 volts?
running an aq2200 at half ohm on a mechman 320 and getting an xp 3000 or d3100
maybe putting my d1200 under the hood or selling it, will i be able to stay at 14 volts full tilt?
also what would be better the d3100 or xp3000
Should be more than enough. Just make sure your wiring is up to par. You could be 14v+ at the alt but voltage drop to the back might take you down a fraction of a volt
Okay I just have been dropping to like 12.8 and thats no fun so time for another agm. What would be better d3100 or a xp3000
Mid 13s
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
XP3000. As long as the battery isn't in the engine bay.
They are the same on the inside. The D series has a thicker case so it can be used under the hood. The XP is cheaper because the casing is thinner
  • Who's Online   0 Members, 0 Anonymous, 2127 Guests (See full list)
