way too much power. way way way too much power. 3k 3.5 tops.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I was just about to say, that's a whole lot of power for a 3" coil.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
lets put it this way. my way is 17 cubes.
4 2500s at .7 per. so realistically in that 3 to 3.5k range and I can stink em up if i want to. (yes I know what they can do on good electrical)
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
3-3.5 for 9500s? good to know I was under the impression they could handle 6k. I'll keep that in mind and not turn them up too much.
also should finally be posting pics of a few things within the next few days, now that I have cleaned out the garage I will start unpacking stuff and moving stuff to the garage and gradually making stuff work it's way into the car :) also gotta wait on a new charger for my laptop to come in cuz mine just stopped working...
and who knows might end up just going ahead and either reconing to D1s or getting 3500s and selling the 5500s at some point.
Thanks I was pretty excited about the alt myself. kind of like a school girl, in a dress, on a swing. lol
It's warming up enough that the donut-punching cyclist douchenozzles are getting their two wheeled fagmobiles out.
My Build Log
You could just run 1 5500
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
That's what the reconeing to D1 woulda been for... run them on 1 5500 and still be able to wire at 1 ohm
My Build Log
  • 1 month later...
omg... it's a miracle... over the last few weeks or so I've actually done some work on this thing lol
used a hole saw to make the holes for my ports then discovered the hole saw wasn't quite big enough so ended up having to use a wood file and sandpaper to make the holes bigger so I could fit my pipe in it... my pipe is too big for the hole ;) lol
finally got all the holes big enough and got my pipe cut to length and discovered I had lost one of my elbows :( so I got all 3 pipes in but one of them still needs an elbow before I can actually put it all together and call it done and haven't had a chance yet to go get another one
also glued my baffle together and put everything up to set
then the weekend before last was my brother's wedding so got kinda crazy doing last minute stuff for that so didn't work on it so ended up sitting for a while but at least things hopefully got nice and dry lol started back up earlier this week gluing things together
got all the plain walls all glued together but didn't have the key to get to the power tools in the shed so couldn't cut out the holes for my subs and still never did find that elbow so the baffle and port wall just had to wait
you can also see my new'ish CR-X and my brother's 69 grand prix back in the background looking awesome lol
was a little lazy and pressed for time and rather than trying to cut my boards with a circular saw I went ahead and took advantage of home depot having a panel saw and had them cut it since the whole board wouldn't have fit in one piece in my car anyway... last time I do that... dude didn't cut my dimensions that I asked for and this side piece is way off... gna probably end up tryina use shims or something to fill that in I feel like that is probably way too big a gap to try to just fill in with glue or something :(
oh yea I also picked up a few of these... torque head screws
My Build Log
today I finally had access to the power tools so I got started on my battery mount and doing some more work on my box
first side I glued for my battery mount ended up gluing crooked :( didn't notice till after it dried though and didn't feel like cutting it all again
while that was gluing went ahead and started cutting the holes for my subs
then I was kinda glad I had picked up some clamps that worked for squeezing and pressing cuz at first I wasn't quite sure how I was gna keep this next piece in place but I think this worked out nicely :)
I did actually finish doing those walls all the way across and also glued on the baffle to the rest of the box but forgot to get pics of that before I went to class and now it's dark so I'll have to get those some time either tomorrow after work or saturday when I should hopefully do the finishing touches on the box and hopefully load the batteries into the trunk and wire them up so I can actually have them charging I REALLY hope I didn't let them sit so long that they died
My Build Log
