covi1234 Posted May 16, 2013 Report Posted May 16, 2013 Going to start replacing the component speakers in my tahoe. The rear knew that are in the roof are 4x10. Is there a good brand to go with? I also seen a kit that converts them to 6x9. What would be the best route to go?
john253a Posted May 16, 2013 Report Posted May 16, 2013 You could also do 2x 4" in each If there only for surround and you have subs in car A single quality 4" coaxel or component will do survive Like the RF T142 If you don't have subs then look into a 6x9 Or mid to suit a 6"
MeenGreenAudio Posted May 16, 2013 Report Posted May 16, 2013 Go with kicker if your gonna keep the 4x10 but I would personally get the 6x9 adapter Build Log 1996 chevy suburban 2 zv4 15 kenwood excelon mids and tweeters kenwood excelon deck mevhman 370 3 batts all different mechman avmb II 2 inch squat 33 inch muds straight pipes kixker zx series 4ch sundown amps memphis 0 gauge soon to be fu audio c pillar wall
covi1234 Posted May 16, 2013 Author Report Posted May 16, 2013 I do have subs. And it is just for the surround effect
covi1234 Posted May 16, 2013 Author Report Posted May 16, 2013 http://www.amazon.com/Rockford-Fosgate-P142-Coaxial-Speakers/dp/B001P86T1U anyone ever have any luck with this one?
john253a Posted May 16, 2013 Report Posted May 16, 2013 If its just surround in the rear 1/2mdf adaptor and a good 4" is all you need And if you front stage is strong enough you don't even need rear fill unless you have passengers back there all the time And if you go with a 4" coaxel you can get high end for under $100
john253a Posted May 16, 2013 Report Posted May 16, 2013 If you like RF Go with the T series at $75 http://www.sonicelectronix.com/item_19823_Rockford-Fosgate-Power-T142.html
bcbrassard Posted May 18, 2013 Report Posted May 18, 2013 I agree with going with the T142s, i installed them in the dash of my sons 94 Tahoe and they sounded great highpassed off a P200-2 and can take the power. I also just took a dremel and cut out the rear for a pair of T1692s where the 4x10s are. Only because i had an extra set lying around. Before that we had the Kicker 4x10s in there and the sounded great with good mid & highs. But with subs you dont hear them from the front now matter what you put back there. Maybe the rear passenger does but realy who cares! lol The boys Tahoe has 10 speakers ranging from 4" to 6x9s for mids and highs with 2 15"s in the back. 5 amps to run it all and ALL RF products. Not the Best SQ But SPL i thinks it does well. So lots of ideas to choose from, just all depends on what you want to do. Good luck and let us know.
