classic100% Posted May 16, 2013 Report Posted May 16, 2013 I will like to play 4 10 inch for mid bass, I planned on wiring them to 4 ohms and playing them on a 4 ohm bridged amp..., but I was advised by another hobbiest that it would be a lot better if I can get 4 speakers that can be wired to 2 ohms and be played on a 2 ohms stable amp. so that it would be louder. I am looking for loudest and cleanest option. Any thoughts on this?
reg93f150 Posted May 16, 2013 Report Posted May 16, 2013 running at 4 ohm's would be great if you could have the amp that could power those 4 10's at 4 ohms instead of 2 ohms. 4 ohms should probably be cleaner and i dunno about louder then 2 ohms but someone else can chime in on that? crescendo would be a good mid bass option for loudness and clarity really ALL CREDIT TO XX1 FOR DC BANNER down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups strapping 2 amps together ? like bolting them next together? using bungy cables to hold them down? or wiring separate amps to each sub
mothra Posted May 16, 2013 Report Posted May 16, 2013 4Ω or 2Ω is not the question. if you can power them with an amp bridged @4Ω you're good. there is no difference atleast none that would make you actually buy one way or the other. if nothing changes, nothing changes You don't know what you don't know, till you don't know
classic100% Posted May 16, 2013 Author Report Posted May 16, 2013 The rms of the speakers equal to 1300 watts would a 1200 be enough or do I need to go to 2000 watts amplifier. The speakers a beyma 10g 40
black05alti Posted May 17, 2013 Report Posted May 17, 2013 you could get away with only giving them 1200, but i'd probably push 1500 to them.
