i do not know if something is wrong but when i am in drive just sitting at redlight the volts are at 12.4- 12.5 when i am driving they are at 14.1-14.2 then when i am just going slow it is at 13.4-13.5
my factory alt had more volts in drive then this one. my factory alt when i was in drive sitting at red light it was 13.2
do ya'l think there is something wrong with this one??????
cold start is like 14.4
large altenators normally have a lower idle amperage than a smaller alt
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
that is amperage not voltage
well if its not puting out enough amperage the voltage is going to drop
DC.jpgDC POWER
read up on ur electrical info bro
and read wut stephen said
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Is your alt belt tight?
u prolly do have sumthin wrong
i have heard that kicker amps are a bit of amp suckers but i dont know about that especially with another battery in the back
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
plus this all happens when the vol is all the way down
i checked the pulleys on both and they are the same
